Cutting out wot
mrdoorguy
Ok here's my mods
stock stroke stock bore
2 into intake 38mm keihin carb
trinity stg 4 head 18 cc domes 108-112 octane gas I run
toomey t6 pipes and silencers
v3 reeds
so I had my jugs drag ported by hjr. Put it all back together and it fired right up. Went through heat cycle etc.
Runs great at idle and mid range. When I get it on the band it starts pulling really hard then starts cutting out. I had a 200watt Ricky stator. Changed it back to oem heard they are better. I took the jet out of the bott of the carb it read 188. I went to a 182 and worse. Went to 190 got a little better. Should I keep going bigger. Let me know. Thanks a bunch everyone.
try 205 main
my altitude is 2800 feet. my timing is +6. I went down to the shop the biggest he had was a 200.
i put it in still cutting out. i can have him order some more.
what sizes should i get? they are $3.00 a piece. so i dont mind buying a few extra.
whats the biggest size i could run. and what other stuff should i be checking while while i wait for them to come in?
any help would be great thanks everyone!!
Ok got some new info. I put in a 230 main.
Cuts out bad. This may seem crazy but
it doesn't miss at wot in first or in neutral or with clutch in.
After 1st gear it starts missing. What do you
guys think now.. By the way with the 230 in
it idled very low it didn't like it. I'm wondering
am I maybe getting water in the cylinders. Or no way. H20
equals white smoke right. Please any help would be great. I'm
getting kinda stressed and nervous!
Sounds way to familiar!! Put on some new plug caps at least, if not replace the plug wires and all ends!! Just my .02, but in my early years of banshee ownership I had the same issues and spent about 3 grand trying to figure it out!! LOL I did end up with a new cheetah set up out of the deal, but it was all solved by the purchase of new plug caps!! It pipped and missed on topend!! Good luck!!
Z
Z
K
I'll try it. Do I need to buy them from a shop
or can I buy them from an auto part store and
make them the correct length and crimp the ends
on. Any specific brand or style you guys think is best?
Thanks
You could ohm the caps, don't have the value in front of me ,it's in the Clymers. If you replace them use NGK, cut 1/4 inch off wire before install. X-2 on leakdown. Did you talk to your builder/porter about your set-up you're running? I don't know a lot about different set-ups but IIRC, T-6s are for stock cyl, and single carb are mostly for trail set-up at best. With drag porting you might not have a strong enough signal at low rpms and not enough carb for high rpms , along with the pipes choking it. banghead JMHO, your results may and will vary. :cheers:
