bansheeman2002 Posted February 9, 2011 Report Share Posted February 9, 2011 here is my new 2002 shee got a good deal on it have a hard time starting and kinda runs shitty it has great spark in the process of cleaning the carbs hope that does the trick Quote Link to comment Share on other sites More sharing options...
bluebanshee421 Posted February 9, 2011 Report Share Posted February 9, 2011 You could also check the pistons to make sue they're in good condition, um make sure it hasnt sucked in any reeds and just go from there and congrats on the new bike your gonna love it. Quote Link to comment Share on other sites More sharing options...
bansheeman2002 Posted February 9, 2011 Author Report Share Posted February 9, 2011 You could also check the pistons to make sue they're in good condition, um make sure it hasnt sucked in any reeds and just go from there and congrats on the new bike your gonna love it. the po rerung it this sunmmer has great comp and yeah ill make sure to check the reeds they a VF3 Quote Link to comment Share on other sites More sharing options...
bluebanshee421 Posted February 9, 2011 Report Share Posted February 9, 2011 I have had problem with them comin out so yea. Quote Link to comment Share on other sites More sharing options...
crustydemon Posted February 9, 2011 Report Share Posted February 9, 2011 Looks good! Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted February 9, 2011 Report Share Posted February 9, 2011 describe why your bike seems to be running like shit? as in what symptoms does it have? Quote Link to comment Share on other sites More sharing options...
06specialedition Posted February 9, 2011 Report Share Posted February 9, 2011 Congrats on the purchase! I would suggest not riding it until you work out the little bugs and make sure your jetting is on. Quote Link to comment Share on other sites More sharing options...
bansheeman2002 Posted February 10, 2011 Author Report Share Posted February 10, 2011 describe why your bike seems to be running like shit? as in what symptoms does it have? well we got it started a few times and it scrreemed but its hard to get started and stay running Quote Link to comment Share on other sites More sharing options...
MN SHEE Posted February 10, 2011 Report Share Posted February 10, 2011 sounds like the choke tube between the carbs is off. are the carbs stock? Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted February 10, 2011 Report Share Posted February 10, 2011 if they are stock carbs that are on the bike....then there should be a black tube that goes between the carbs. If its there then that could be the problem with your bike. They need to be balanced and the tube causes one of the carbs to not be choked when your missing that tube. Quote Link to comment Share on other sites More sharing options...
bansheeman2002 Posted February 10, 2011 Author Report Share Posted February 10, 2011 you know what there was no tube there when i took them off would that make it run so crappy and not start Quote Link to comment Share on other sites More sharing options...
MN SHEE Posted February 10, 2011 Report Share Posted February 10, 2011 where the choke is on the left carb at the front look straight across twards the other carb the tube should be 2 to 3 inches long if you dont see one pull one of the carbs off and get a better look its # 42 there is a link to it also you will have to look for it just put in http://www.yamahapar...nd/default.aspx Quote Link to comment Share on other sites More sharing options...
4MiLLDraGSheE Posted February 10, 2011 Report Share Posted February 10, 2011 Mine was doing the same exact thing to be honest. It ran fine then would take like 100 kicks to start and would bog down... so i went with complete overhaul... new cylinders new carbs new.reeds new crank new intake.new pistons new everytbing... Quote Link to comment Share on other sites More sharing options...
bansheeman2002 Posted February 10, 2011 Author Report Share Posted February 10, 2011 you know what there was no tube there when i took them off would that make it run so crappy and not start nope that tube was never there when i took the carbs off ill make sure to put one in thanks and i hope this makes it run better Quote Link to comment Share on other sites More sharing options...
banshee55 Posted February 11, 2011 Report Share Posted February 11, 2011 4 mill i did the same exact thing... Hah 500 bucks later it runs perfect now! Quote Link to comment Share on other sites More sharing options...
