help need opinions
tipn22
i need some opinions i think my banshee is running rich on the left side
i just put a motor in ,synced the carbs pilots at one and a half turns out i adjusted them and it didnt seem to help, and the carbs are clean inside and out its almost stock pipes,filter ,filter box ,main jets 200, pilots not sure but think there stock is well only thing not stock is my noss cool head and not sure of dome size
need opinions ?
here is a video
the ticking is the clutch handle and the pipes hitting againest the frame
What makes you think it's rich on the left? Is this only at idle or all ranges?
it smokes alot more out the left side all ranges and the oil build up at the end of the left pipe and it also spits oil only out the left pipe
after start up or running it for an hour its always the same oil build up and smoke
im i just trippin :confused:
it can be that you have a bad gasket in that carb? sometimes a gasket goes bad so it just pours gas in there. run it hard and do a plug chop. and dont be affraid to jet for each cylinder. both dont have to be 200. maybe a 200 and a 210 etc.
ok maybe it is the gasket it also drips gas out the over flow on the same carb
ok just got new gaskets and sealed my carb boots leak down was good pipes are good carbs seem ok there is no porting an reeds not sure about, ganna see how it pans out
if the inlet vavle was bad what would it do besides leak gas out the over flow?
Edited by tipn22
i just took it out and it was fixed but it was running lean cuase i did the choke test and it idle higher when i pulled it out,
so i adjusted the pilots two turns out all together and now it runs and perfect :dance:
video befor new gaskets
video after new gaskets and and pilots adjusted
Edited by tipn22
