n2otoofast4u Posted February 6, 2011 Report Share Posted February 6, 2011 Ok stop! Does the bike have an override? Is there a solenoid at all involved with the shifted system? That appears to be a compressed air set, not an inert gas setup. If you have no override, is there any wires going to the coil cdi or anything else? Take an air compressor and put air in the valve on the bars to 100psi and listen/watch/look for any leaks... do not touch anything! Just report back with answers to my other questions, and whether or not the system leaks... you can ruin parts at a stand still if you aren't careful... ok, now the battery and nitrous... does the battery have wires to anything but stuff that is wired to the nitrous? One solenoid is a cold fusion and the other is maybe a dyno tune, or maybe a ? Hell who knows dyno tune? At any rate. Post a pic of the nozzle setup. There are tons of things that need to looked at on that entire bike.. nothing you can't get through but you can cause great harm by doing something that you shouldn't... also, are there fancy electronics on the bike? Dyna cdi, or extra rectifiers or anything? ? Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted February 6, 2011 Report Share Posted February 6, 2011 (edited) Ok, so I took a closer look. The one button is going to be built into the perch setup that has the gauge setup. That will be the shift button.. is there any parts on that on that component that go to others. It looks like it goes to a solenoid, making it an air over electric setup. The other switch should be added on? That will be the nitrous switch. Honestly there isn't a one of those things gonna do you any good without some others.. if you don't have a good knowledge of both you ate probably better off removing them.. if that's not an option, then I will help as much as I can but there's nothing good about that current setup unless its got an override and a few other things. Edited February 6, 2011 by n2otoofast4u Quote Link to comment Share on other sites More sharing options...
nsrt4 Posted February 6, 2011 Author Report Share Posted February 6, 2011 I dont know why it has a single carb how much would it cost to go back to 2 carbs and would it be a pain in the ass Quote Link to comment Share on other sites More sharing options...
