jacquesraney Posted February 3, 2011 Report Share Posted February 3, 2011 do i need to fill the coolant resevoir under the seat?? is it for back up??? Quote Link to comment Share on other sites More sharing options...
tedd1 Posted February 3, 2011 Report Share Posted February 3, 2011 Check that the overflow from the rad connects to the bottom of the res. There are marks on the res, keep it about half full. I don't run it. If you take it off, you will have to pull the rad cover to check coolant level. Quote Link to comment Share on other sites More sharing options...
bansheerage Posted February 3, 2011 Report Share Posted February 3, 2011 take it off and just monitor your rad. run the hose under the gas tank somewhere. i have mine going up the frame. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted February 3, 2011 Report Share Posted February 3, 2011 I run mine because it keeps the radiator topped off. As coolant heats (expands) and cools (contracts). It will burp any trapped air and when it cools down it will pull coolant back into the radiator. I keep mine about hafl full when cold. Quote Link to comment Share on other sites More sharing options...
