Full Flight Arms with 450 shocks......issue!
12 0 Clock P I M P
Just put my 450 shocks on my +2+1 Full Flight A Arms...........the upper a arm is hitting the bottom of the shock block (where the adjustment is) at Full extension.....
I bought the bike with these arms and do not know if they are for stock shocks or long travel...regardless i searched and have not seen anyone with this issue.......what gives???? here are pics
It's hard to see in the pics, but after you try turning them around you need to make sure that that hiem joint isn't binding before the shock is fully extended. With those shocks being longer than stock you could break one of those hiems if that is what stops your a-arms from traveling down.
