4mil cylinders 7 mil crank
I have a 7mil crank and im getting cylinders set up for a 4mil long rod crank do you think this would work if i used a 4mil spacer plate? I have heard of guys running a 10mil crank on 7mil cylinders and just taking the extra 3mil out of the head...so i cant see why this wouldnt work.
HMM its been some time, but I believe you should be able to have some domes made so that you wont need to run the stupid spacer plate. Im pretty sure that with the right piston and a recessed dome you can do it without a plate.. You will have to adjust your porting no matter what you do Im sure.
Yup that is spot on..................
