njdevil26 Posted January 22, 2011 Report Share Posted January 22, 2011 hey guys. i just picked up a banshee that has resivors for the shocks. first time ever running this setup. i have no idea what brand they are, sorry. but i geuss my question is if i can just run regular air in there or if it should be nitrogen. ive heard 50/50 reviews on it. i do a little bit of everything as far as my riding goes but am thinking about doing more mx this yr. help me guyyysssss!!!!! Quote Link to comment Share on other sites More sharing options...
Phelps Posted January 22, 2011 Report Share Posted January 22, 2011 only compressed nitrogen! depending on what you have depends on recommended pressure. Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted January 22, 2011 Report Share Posted January 22, 2011 Nitrogen only. Do not run regular air under any circumstance. You need to find out what brand shocks they are, though, as different brands require different pressures. Quote Link to comment Share on other sites More sharing options...
njdevil26 Posted January 23, 2011 Author Report Share Posted January 23, 2011 is there a reason for the nitrogen? Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted January 23, 2011 Report Share Posted January 23, 2011 Yes, it's 100% dry, so it won't allow rust to develop, also it doesn't react to temperatures. If you pressurize your shock with air at 50*F, then the shock heats up to 200*F, the 200 psi you out into your shocks will all of a sudden be at 250 or more just from the temperature increase. Quote Link to comment Share on other sites More sharing options...
