Duke 2 Stroke Posted February 15, 2020 Report Share Posted February 15, 2020 On 2/12/2020 at 6:11 PM, specialblend07 said: Buy a Mikuni fuel pump. Don’t listen to the other guy rambling. Sent from my iPhone using Tapatalk Do you know what Mikuni fuel pump I should look for? From which model bike? Any info would be helpful Quote Link to comment Share on other sites More sharing options...
alcoholbanshee Posted February 15, 2020 Report Share Posted February 15, 2020 8 hours ago, Duke 2 Stroke said: That was some very good advice and knowledge you shared there brother. Thanks for the advice and I will definitely look more into this before I think about attempting this. Not so much on the good advice. He is overthinking the hell out of it. Do a little research on snowmobile fuel pump systems. All you need is a port in one of your intakes for the pulse, a fuel pump ( most any 2 cylinder snomo pump will work) and the proper needle/seat assemblies in your carbs. Its that simple. Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted February 15, 2020 Report Share Posted February 15, 2020 ^ ^ ^ doesn't over think ^ ^ ^ Quote Link to comment Share on other sites More sharing options...
Duke 2 Stroke Posted February 18, 2020 Report Share Posted February 18, 2020 On 2/15/2020 at 9:34 AM, alcoholbanshee said: Not so much on the good advice. He is overthinking the hell out of it. Do a little research on snowmobile fuel pump systems. All you need is a port in one of your intakes for the pulse, a fuel pump ( most any 2 cylinder snomo pump will work) and the proper needle/seat assemblies in your carbs. Its that simple. On 2/15/2020 at 9:34 AM, alcoholbanshee said: Not so much on the good advice. He is overthinking the hell out of it. Do a little research on snowmobile fuel pump systems. All you need is a port in one of your intakes for the pulse, a fuel pump ( most any 2 cylinder snomo pump will work) and the proper needle/seat assemblies in your carbs. Its that simple. So their are different needle/seat assemblies as well? Do you know exact needle/seat assembly I need to order? Quote Link to comment Share on other sites More sharing options...
registered user Posted February 19, 2020 Report Share Posted February 19, 2020 what r u using da bike for? Quote Link to comment Share on other sites More sharing options...
SKEETER Posted February 19, 2020 Report Share Posted February 19, 2020 Riding. Duh. Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted February 19, 2020 Report Share Posted February 19, 2020 If you are asking about fuel pumps......... you don’t need a fuel pump. Quote Link to comment Share on other sites More sharing options...
SKEETER Posted February 19, 2020 Report Share Posted February 19, 2020 ^^^^ Quote Link to comment Share on other sites More sharing options...
