ColdDogCat Posted January 7, 2011 Report Share Posted January 7, 2011 Okay, i got a stock axle...looking for some new wheels...what offsets will fit...i guess 3+2 is standard right. But some wheels i look at have offsets of 47mm and 10mm..and how wide, tall, IDK i need help Quote Link to comment Share on other sites More sharing options...
Hilarious Posted January 7, 2011 Report Share Posted January 7, 2011 Okay, i got a stock axle...looking for some new wheels...what offsets will fit...i guess 3+2 is standard right. But some wheels i look at have offsets of 47mm and 10mm..and how wide, tall, IDK i need help What exactically are you wanting to accomplish? Are you tring to narrow or widen the rear without purchasing an aftermarket axle with adjustable hubs? Quote Link to comment Share on other sites More sharing options...
ColdDogCat Posted January 10, 2011 Author Report Share Posted January 10, 2011 would like to widen Quote Link to comment Share on other sites More sharing options...
Hilarious Posted January 21, 2011 Report Share Posted January 21, 2011 i forgot all about this thread. i am sure you have found wheels by now>? i think the stock rear wheels are 9x8 with 3 + 5 offset. 8" wide wheel with the center mounting area being 3" from the inside and 5" from the outside of the wheel. i am not sure if you can get a greater offset that this in the rear wheels. the further away the center of the wheel is from the hub and axle, the more stress it will put on that hub/axle. if you arent jumping off of buildings and such, you may look into some wheel spacers as that would be a cheaper alternative to an aftermarket adjustable axle. i would much rather spend my money on an axle but i know a lot of people that get away with the spacers. Quote Link to comment Share on other sites More sharing options...
