Fastassbanshee96 Posted January 1, 2011 Report Posted January 1, 2011 What brand are the carbs? Are they set up for alky or gas? Is the intake one with the built in crossover? Quote
badassbanshee479 Posted January 2, 2011 Report Posted January 2, 2011 What brand are the carbs? Are they set up for alky or gas? Is the intake one with the built in crossover? pwks are made by keihin. good carbs for sure Quote
jbooker82 Posted January 2, 2011 Report Posted January 2, 2011 Looks like they are air strikers as well. Quote
duner Posted January 2, 2011 Author Report Posted January 2, 2011 I guess I should be a little more detailed. The guys are correct, Keihin makes them, they are air stykers, on gas,the intake has the built in crossover. Quote
KickStartMyHeart Posted January 2, 2011 Report Posted January 2, 2011 I guess I should be a little more detailed. The guys are correct, Keihin makes them, they are air stykers, on gas,the intake has the built in crossover. Post a pic of the intake side of the carbs and that will show if they are airstrikers or not. If they are airstrikers they will have two little fins on the inside. Quote
badassbanshee479 Posted January 2, 2011 Report Posted January 2, 2011 Post a pic of the intake side of the carbs and that will show if they are airstrikers or not. If they are airstrikers they will have two little fins on the inside. if you look at the vent lines you can see the 2 extra vent hoses coming out by the carb cabs..... just another tell tail sign of air strikers. Quote
KickStartMyHeart Posted January 2, 2011 Report Posted January 2, 2011 if you look at the vent lines you can see the 2 extra vent hoses coming out by the carb cabs..... just another tell tail sign of air strikers. Very good point kind sir. Quote
