yamahaman244 Posted December 30, 2010 Report Share Posted December 30, 2010 hey guys today was gunna take my stator cover off to change my front sproket.....and the bottom screw by the shifte looks to be striped could get it to move....how the hell can i get it out....? and my other qustion is my fuel pecock is leaking gas sometimes it dont but if u put it on reserve it leaks pretty bad....and it gets to the point were my engine starts missing witch im gussing........................... is its not getting enough gas like it should cause its leaking...do i just need a new gasket for it or what any advise would be nice thanks Quote Link to comment Share on other sites More sharing options...
bigboybanshee Posted December 30, 2010 Report Share Posted December 30, 2010 hey guys today was gunna take my stator cover off to change my front sproket.....and the bottom screw by the shifte looks to be striped could get it to move....how the hell can i get it out....? and my other qustion is my fuel pecock is leaking gas sometimes it dont but if u put it on reserve it leaks pretty bad....and it gets to the point were my engine starts missing witch im gussing........................... is its not getting enough gas like it should cause its leaking...do i just need a new gasket for it or what any advise would be nice thanks Is your stator cover bolt a phillips head or allen head bolt? For your petcock, if it was the gasket, it would leak all the time no matter which position it's in. It sounds like you need a new petcock to me. Quote Link to comment Share on other sites More sharing options...
yamahaman244 Posted December 30, 2010 Author Report Share Posted December 30, 2010 Is your stator cover bolt a phillips head or allen head bolt? For your petcock, if it was the gasket, it would leak all the time no matter which position it's in. It sounds like you need a new petcock to me. um.. its the phlips head screw and it leaks just alittle when off but min u put it on res it drips from the bottom Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted December 31, 2010 Report Share Posted December 31, 2010 You can take apart and rebuild the stock petcock with parts from your local hardware shop like ACE hardware or TrueValue. If you don't want to deal with it any more, just buy a pingle and be done with it. Much better design anyway. While you're at your hardware shop getting the parts you need to rebuild your petcock, just pick up an easy out set for the stuck bolt. You can also drill the head of the bolt off (very carefully) and remove the cover, then grab the little stub of whats left of it with some vice grips and twist it out. In either case, your threads in your case are probably going to be buggered up, so pick up a thread tap and re-do your threads while you have the cover off. Blast the hole out with some carb cleaner as well, a lot of times dirt and sand get into the holes and when you put the bolt in it mashes the sand up in the end of the bolt hole and wont let the bolt thread in as far as it should and it strips out. easy out / drill bits / tap & die set to fix threads / new allen-head bolts for the cover. Quote Link to comment Share on other sites More sharing options...
