motor issues
Chase624
so i went riding today and my banshee has kinda had this problem for a while and i cant figure out what it is. so heres whats going on my left cylinder stop working at low end /bogging and when i give it some throttle and put a load on it it kicks in and runs like a drag racer but as soon as i let up a little the left cylinder bearly is kicking over and the right one runs perfect and it has new plugs coil and stator so please help thank you:)
Edited by Chase624
my bike was doing the same thing when i first picked it up.....turned out to be too small of a pilot jet (stock). what pipes are you running and what pilot jet do you have in the bike? may want to try and jump up one size...
well the other cylinder runs great and my altitude is 4800 feet and im running paul turner high rev pipes with a cool head and timing plate
my left cylinder was doing the exact same thing.....the right was running perfectly fine (or it seemed) and at idle it would run fine......give it a little throttle and the left cyl would cut out and around when i hit mid-throttle (where the main needle was really startin to open up) the left cylinder would actually come back and it would run like a raped ape...
Yes that's exactly what it's doing how do you fix it?
my bro rebuiit with new carbs cylinders and it ran like shit overheated and lost compression hes going to rebuild it the same way again with some new pistons man i feel like slapping him lol hay i get slapped all the time haha
