Alcohol carb?
Alcohol carbs will have a powerjet on the filter side of the carb. Next, the main jet and dump tube will be drilled out larger. Usually in the .116-.118" range, sometimes as big as .120". Then they will have bigger pilots and a physically smaller needle to flow more fuel. The needles will have a faster taper and a shorter overall length compared to a gas needle. If they are keihin carbs your needles would be like an EGL or EGQ... around in there. Gas needles are usually a C or D series.
If they have drilled mains and dumps and the alcohol needles, but no powerjets then whoever set them up is a tard-o.
Edited by BigRed350x
Ok well I just spoke with wicked and he confirmed that they were alky. I bought them from a guy on here who told me they were setup for gas. What would happen if I switch the needle back and jets and run gas thru them.
It would run like poo. If the dump tube is drilled out and you put a gas needle in there, the gas needle won't be able to plug up the dump tube like it should. You would be pulling fuel around the needle all the time, when its not supposed to, making you really rich. It would never have a chance to clean out and would just bog everywhere. I had a set of carbs like this one time and it was a lost cause. I scrapped what parts I could off of them to use as spare parts on other carbs and chucked them in the trash.
If you want gas carbs you could always sell these with the correct advertisement as alcohol carbs and use that money to buy gas carbs. Or work up a trade.
