wakullabanshee Posted December 17, 2010 Report Share Posted December 17, 2010 Ok just went to sears and got a compression tester http://www.sears.com/shc/s/p_10153_12605_00947089000P?prdNo=9&blockNo=9&blockType=G9 to check compression and both cylinders are at ( 160) with 6 to 7 kicks. The problem is i can only pull start it but when you get it to run and warm up you can kick start it but if you let it sit over night you have to pull it again.. What octane would you run in this thing. Quote Link to comment Share on other sites More sharing options...
shoopie Posted December 17, 2010 Report Share Posted December 17, 2010 you should be running around 97 octane with that compression. i have the same problem right now with the starting, its because of the temperature drop, your jetting is too lean for the temp. go up a couple sizes in the main jet and it should start fine. Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted December 17, 2010 Report Share Posted December 17, 2010 what pilot jets are you running? and what carbs are you running? the pilot jets have alot to do with how your bike will start Quote Link to comment Share on other sites More sharing options...
moneybags Posted December 17, 2010 Report Share Posted December 17, 2010 Could try turning in the air screws alittle to help ritchen up the bottom end. If that helps you will still need to ajust your main jets. Quote Link to comment Share on other sites More sharing options...
wakullabanshee Posted December 18, 2010 Author Report Share Posted December 18, 2010 Could try turning in the air screws alittle to help ritchen up the bottom end. If that helps you will still need to ajust your main jets. I tryed that and nothing. Quote Link to comment Share on other sites More sharing options...
wakullabanshee Posted December 18, 2010 Author Report Share Posted December 18, 2010 you missing the choke tube? Ye the choke tube is on. I do have stock carbs, I was thinking just going buying alittle bigger carb good or bad? When i got this thing he said it was just rebuild its got a cool head have no idea what domes, sst exhaust do have a air box but with no lid Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted December 19, 2010 Report Share Posted December 19, 2010 what is your jetting at? Quote Link to comment Share on other sites More sharing options...
