patrickkomar Posted December 14, 2010 Report Share Posted December 14, 2010 I did a full rebuild on my shee and now my jetting seems off on the lowend. My bike before the rebuild was in pretty sad shape, it was .60 over with pro light pistons, 18cc domes ( only had about 110 psi on both cylinders ) +4 on the timing, T-5 pipes, stock carbs(30 pilots 350 mains needle in the middle slot) v force 2 reeds, K&N pods. The bike now is .10 over with pro lights, crank is a welded and trued stock, wildcard dune port, 19 cc domes, v force 2 reeds, K&T's single piece intake, same stock carbs with the same jetting only thing that changed was i put in toomys needle, same pipes and pods, the timing has been bumbed to 6. The bike will not idle and bogs really bad if you let get close to an idle and is a bear to try and start. where should I start here???????????????? Quote Link to comment Share on other sites More sharing options...
bansheesrtoys Posted December 14, 2010 Report Share Posted December 14, 2010 try going back to the +4 on timing Quote Link to comment Share on other sites More sharing options...
Wildcardracing Posted December 14, 2010 Report Share Posted December 14, 2010 Pat, Just give me a call when you have time and I'll get you set up. Those new cylinders are going to require very different jetting than your stock ones. -Brandon Quote Link to comment Share on other sites More sharing options...
