hotrodbanshee Posted December 12, 2010 Report Share Posted December 12, 2010 One of my studs on my noss head started leaking some coolent. Pulled the head and replaced the o-rings with some I found at the autoparts store. Thickness of the orings were like .03mm thiner than the origanals. Put it back together and still leaks around the stud. Do any of you guys ever put any type of sealent on the orings when installing a cool head? If so what type of sealent? I may just have to order a complete pro design o-ring set, i really don't need the rest of the o-rings just the ones for the studs. Quote Link to comment Share on other sites More sharing options...
jasons Posted December 12, 2010 Report Share Posted December 12, 2010 One of my studs on my noss head started leaking some coolent. Pulled the head and replaced the o-rings with some I found at the autoparts store. Thickness of the orings were like .03mm thiner than the origanals. Put it back together and still leaks around the stud. Do any of you guys ever put any type of sealent on the orings when installing a cool head? If so what type of sealent? I may just have to order a complete pro design o-ring set, i really don't need the rest of the o-rings just the ones for the studs. send jlengineering a pm he has a few set cheaper then what pd has them for. i think he is asking like 15 bucks for the set. as far as your leaking i dont use any sealant just put the oring in and slap it back together never once had a leak issue. Quote Link to comment Share on other sites More sharing options...
crustydemon Posted December 12, 2010 Report Share Posted December 12, 2010 I use a little black rtv around the studs just for insurance. Never had a leak. Quote Link to comment Share on other sites More sharing options...
bansheesrtoys Posted December 13, 2010 Report Share Posted December 13, 2010 i use gease on the o-rings when installing. not talking shit but why would yo want to use rtv? it is messy and a pain in the ass to clean when you take apart.jmo. if you do it right you should be fine. Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted December 13, 2010 Report Share Posted December 13, 2010 You can add a dab of RTV around the threads of the studs when you install your head nuts. Leaking around the studs is a common problem with the noss heads. No big deal, just pull the head nuts, put a little dab of RTV on the threads and re-torque the nuts. Should take care of the problem. Let it dry real good before you fire it up and test it out. Also, make sure the threads are clean before you put the RTV on there. I prefer the red hi-temp gas/oil resistant stuff. - Jared Quote Link to comment Share on other sites More sharing options...
Burt Reynolds Posted December 13, 2010 Report Share Posted December 13, 2010 Are you using the little copper washers? Quote Link to comment Share on other sites More sharing options...
hotrodbanshee Posted December 13, 2010 Author Report Share Posted December 13, 2010 I am using plain steel washers. Are you using the little copper washers? Quote Link to comment Share on other sites More sharing options...
No Limit Powersports Posted December 13, 2010 Report Share Posted December 13, 2010 copper washers and cap nuts should seal you off no problem Quote Link to comment Share on other sites More sharing options...
hotrodbanshee Posted December 13, 2010 Author Report Share Posted December 13, 2010 Where is a good place to get copper washers? I checked a couple hardware stores no luck. They had brass. Going to try some auto parts stores. Quote Link to comment Share on other sites More sharing options...
midlifecrisis Posted December 13, 2010 Report Share Posted December 13, 2010 Has to be a place like Brafasco if you have them in the states, or just gethem from ebay. Heres an ebay number to look at. 290438405409 1 Quote Link to comment Share on other sites More sharing options...
hotrodbanshee Posted December 14, 2010 Author Report Share Posted December 14, 2010 Found the washers at NAPA. Quote Link to comment Share on other sites More sharing options...
bigblockbanshee Posted December 14, 2010 Report Share Posted December 14, 2010 Same washers as a banjo fitting in a brake line uses, just have to find the correct size. Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted December 14, 2010 Report Share Posted December 14, 2010 o-ring your stock head and scrap that cool head junk. If you insist on using the cool head stuff, charriot seems to be the best. Quote Link to comment Share on other sites More sharing options...
J-Madd Posted December 15, 2010 Report Share Posted December 15, 2010 Same washers as a banjo fitting in a brake line uses, just have to find the correct size. That's good to know what they're called (banjo fitting). I've never had luck looking for them either. NIce car. Quote Link to comment Share on other sites More sharing options...
bigblockbanshee Posted December 15, 2010 Report Share Posted December 15, 2010 That's good to know what they're called (banjo fitting). I've never had luck looking for them either. NIce car. Thanks! Quote Link to comment Share on other sites More sharing options...
