lt_ron Posted December 10, 2010 Report Share Posted December 10, 2010 I got a frame a little while back and one of the foot peg bolts is striped it is the rear one of the two I thought of drilling it out and welding me a nut inside there with the tig or hei coiling it but I wanted to get some ideals of what everyone has done here is a pic showing witch one Thanks Quote Link to comment Share on other sites More sharing options...
crash&burn Posted December 10, 2010 Report Share Posted December 10, 2010 is it the bolt or bolt hole.... any ways one of the ways below should help you out 1. if its bolt with a rounded head there is easy outs that will go over that stripped head and bite into it tighter and tighter when you go to loosen the bolt it will break it or take it out.... i have set use the on takin out old head steads works great.... 2. if the bolts snapped i would drill a hole in the middle and easy out it that way... guessing that is nice powder coated frame and you don't want screw it up if you have little propane torch apply some heat strictly the bolt it doesn't take much heat and it will cause the bolt to contract and break the bond in there and should help it come out easier 3. if its the hole thats stripped out you could try a thread chaser or you could thread it for a bigger bolt 4. fill the bolt hole with a compound either Liquid Steel or J.B. Weld. You've got to love the folks that invented those products! Next coat the bolt liberally with liquid soap Crank the bolt back into the hole and wipe up the excess that squeezes out around the bolt head When the compound is dried, you're set! You can now screw or unscrew at will Quote Link to comment Share on other sites More sharing options...
Burt Reynolds Posted December 10, 2010 Report Share Posted December 10, 2010 Try a longer bolt. If that fails i would tap it. Quote Link to comment Share on other sites More sharing options...
frinkbc Posted December 10, 2010 Report Share Posted December 10, 2010 use an easy out, and id spray some pb-blast around the bolt for a day before ( be careful of the paint wipe and clean off the extra), the next day use the easy out good luck ron. nice roller Quote Link to comment Share on other sites More sharing options...
lt_ron Posted December 10, 2010 Author Report Share Posted December 10, 2010 Sorry guys I should of gave more info I can get the bolt out it just will not tighten up I stuck some sealant on the bolt to hold it in for the track LOL I will try the tap and if that dont work the jb weld trick I thought about doing that but did not know what to put on the bolt to keep it from sticking frink Thanks Quote Link to comment Share on other sites More sharing options...
crash&burn Posted December 10, 2010 Report Share Posted December 10, 2010 is it the bolt or bolt hole.... any ways one of the ways below should help you out 1. if its bolt with a rounded head there is easy outs that will go over that stripped head and bite into it tighter and tighter when you go to loosen the bolt it will break it or take it out.... i have set use the on takin out old head steads works great.... 2. if the bolts snapped i would drill a hole in the middle and easy out it that way... guessing that is nice powder coated frame and you don't want screw it up if you have little propane torch apply some heat strictly the bolt it doesn't take much heat and it will cause the bolt to contract and break the bond in there and should help it come out easier 3. if its the hole thats stripped out you could try a thread chaser or you could thread it for a bigger bolt 4. fill the bolt hole with a compound either Liquid Steel or J.B. Weld. You've got to love the folks that invented those products! Next coat the bolt liberally with liquid soap Crank the bolt back into the hole and wipe up the excess that squeezes out around the bolt head When the compound is dried, you're set! You can now screw or unscrew at will "Next coat the bolt liberally with liquid soap" Quote Link to comment Share on other sites More sharing options...
KlotzBanshee Posted December 10, 2010 Report Share Posted December 10, 2010 The problem is that this is what probably it looks like inside the hole. lol And this is how I fixed mine... Burned in, smoothed out, primered, and painted...viola Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted December 11, 2010 Report Share Posted December 11, 2010 I like that repair !! Hope my grey matter can keep track of that one !! What was the short threaded slug for ASSWHORE ? Quote Link to comment Share on other sites More sharing options...
muggzy Posted December 11, 2010 Report Share Posted December 11, 2010 That is one beautiful repair job and I thought mine was clean. Did you have that insert machined or is it something off the shelf (with mods?) I see that cad dwg but I gotta ask to be sure. And ditto on the short piece? Quote Link to comment Share on other sites More sharing options...
KlotzBanshee Posted December 11, 2010 Report Share Posted December 11, 2010 I drew it on Catia V5 and turned it on a CNC lathe at school. The small piece was for the front mount which I didn't use but might put in when I have my frame PC'ed. I had a friend hit me right in the foot peg with his dirt bike and broke the front mount and bent the rear bolt. The Yamaha dealership welded the front mount (rather shity) and I ended up having to fix the rear myself. Quote Link to comment Share on other sites More sharing options...
muggzy Posted December 12, 2010 Report Share Posted December 12, 2010 (edited) I drew it on Catia V5 and turned it on a CNC lathe at school. The small piece was for the front mount which I didn't use but might put in when I have my frame PC'ed. I had a friend hit me right in the foot peg with his dirt bike and broke the front mount and bent the rear bolt. The Yamaha dealership welded the front mount (rather shity) and I ended up having to fix the rear myself. Nice job. My foot peg was welded to the frame when I got it and I finally cut it off and repaired it this past summer. In case you're interested in what's under that front peg hole you can scroll down through the pics I posted on this other site: http://www.exriders.com/vbb/showthread.php?s=&threadid=441146 I used a helicoil on the rear and build up and filed down the front until I had enough surface to support the peg. So far, it's holding up great. Edited December 12, 2010 by muggzy Quote Link to comment Share on other sites More sharing options...
KlotzBanshee Posted December 12, 2010 Report Share Posted December 12, 2010 Thanks for the compliments guys. Yeah, I have plans to fix the temporary repair on the front mount with the small slug when I get around to powder coating the frame and changing the color skeme. (sp?) I realize there are many different ways to efectively fix a broken foot peg mount, most of which are less involved than this. But with my knowledge and access to the tools to do the job I felt there was only one way for me to do it. It also helps me sleep a little better at night knowing its much stronger than stock, as I am no light weight. lol bout 230lbs Quote Link to comment Share on other sites More sharing options...
muggzy Posted December 13, 2010 Report Share Posted December 13, 2010 Thanks for the compliments guys. Yeah, I have plans to fix the temporary repair on the front mount with the small slug when I get around to powder coating the frame and changing the color skeme. (sp?) I realize there are many different ways to efectively fix a broken foot peg mount, most of which are less involved than this. But with my knowledge and access to the tools to do the job I felt there was only one way for me to do it. It also helps me sleep a little better at night knowing its much stronger than stock, as I am no light weight. lol bout 230lbs There's no question here, your fix is MUCH stronger than stock and if mine fails, I'll be doing it with the insert like you did. Nice job Quote Link to comment Share on other sites More sharing options...
bigblockbanshee Posted April 28, 2011 Report Share Posted April 28, 2011 There's no question here, your fix is MUCH stronger than stock and if mine fails, I'll be doing it with the insert like you did. Nice job If you don't get sucked in under the 'shee when the peg breaks off... Quote Link to comment Share on other sites More sharing options...
bigblockbanshee Posted April 28, 2011 Report Share Posted April 28, 2011 I just replied to a 5 month old thread. Just go ahead and shoot me please... Quote Link to comment Share on other sites More sharing options...
