steeler2169 Posted December 1, 2010 Report Share Posted December 1, 2010 I can only make 3 laps on a mx track, then right forearm starts screaming. Im only 31 so not to out of shape. Has anyone bought any thing that can adjust the thump throttle to be comfy. Quote Link to comment Share on other sites More sharing options...
shoopie Posted December 1, 2010 Report Share Posted December 1, 2010 fuck that. thumb doesnt bother me. my clutch hand gets useless after 5 or 6 hard laps though. Quote Link to comment Share on other sites More sharing options...
jbirdshee Posted December 1, 2010 Report Share Posted December 1, 2010 do you have an extended thumb throttle? if not then you definitely need to invest in one. well worth every penny Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted December 1, 2010 Report Share Posted December 1, 2010 Do you have aftermarket carbs like Kiehin? Those have a lot stiffer slide spings. Jeff at fast sells some lighter tension springs. I dont know if they work for stock carbs though. Quote Link to comment Share on other sites More sharing options...
ban99 Posted December 1, 2010 Report Share Posted December 1, 2010 twist throttle --problem solved. Quote Link to comment Share on other sites More sharing options...
Gummie_guy Posted December 1, 2010 Report Share Posted December 1, 2010 my thumb gets to the point where i cant even really ride anymore depending on the terrain. i mostly do trails though. an extended lever will help with this issue though? Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted December 1, 2010 Report Share Posted December 1, 2010 ride more. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted December 1, 2010 Report Share Posted December 1, 2010 my thumb gets to the point where i cant even really ride anymore depending on the terrain. i mostly do trails though. an extended lever will help with this issue though? Yea but it will also help you hold the throttle WOT. There was one on my banshee when I bought it. The tip of my glove on my index finger would catch the lever as my thumb would push it past. Let off with my thumb and my finger would keep the throttle held open. Quote Link to comment Share on other sites More sharing options...
Gummie_guy Posted December 1, 2010 Report Share Posted December 1, 2010 Yea but it will also help you hold the throttle WOT. There was one on my banshee when I bought it. The tip of my glove on my index finger would catch the lever as my thumb would push it past. Let off with my thumb and my finger would keep the throttle held open. hmm, i never thought of that. ill have to look into investing in one i suppose. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted December 1, 2010 Report Share Posted December 1, 2010 hmm, i never thought of that. ill have to look into investing in one i suppose. I took mine off because I didnt like it doing that. Longer lever requries a longer sweep so you will be pushing your thumb farther forward. Quote Link to comment Share on other sites More sharing options...
Gummie_guy Posted December 1, 2010 Report Share Posted December 1, 2010 I took mine off because I didnt like it doing that. Longer lever requries a longer sweep so you will be pushing your thumb farther forward. hmmm, i didnt even think of that. might try it anyways but is there a way to make it pull easier? i never had a problem on my ex gf's 400ex, so is there a possibility of greasing something and having it at least slide smoother because thats what i feel like mine is, more of a lever issue than from pulling the slides up. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted December 1, 2010 Report Share Posted December 1, 2010 I think you can use a honda thumb throttle. Try the 400 ex thumb throttle on your banshee. See how it fells. If it is good then buy one used off of ebay. Quote Link to comment Share on other sites More sharing options...
Gummie_guy Posted December 1, 2010 Report Share Posted December 1, 2010 I think you can use a honda thumb throttle. Try the 400 ex thumb throttle on your banshee. See how it fells. If it is good then buy one used off of ebay. now are you talking about the whole assembly or just the lever? i might just pick one up and if it ends up not what i want i can always sell it. my shee is under the knife at the moment anyways. Quote Link to comment Share on other sites More sharing options...
rubberneck Posted December 1, 2010 Report Share Posted December 1, 2010 The extended throttle levers lilke the ones cascade sell suck imho. they are ergonomically wrong and you end up pushing the throttle from the same point as stock if not further in. If you have stock carbs you can cut half a coil off the slide spring, if Keihns, get the soft springs from FAST. However, the best thing you can buy is the chariot performance adjustable throttle. With it you can adjust position at idle and it has an adjustable full throttle stop. It will also open carbs up to 41 mm i believe. I have put them on all my bikes. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted December 1, 2010 Report Share Posted December 1, 2010 now are you talking about the whole assembly or just the lever? i might just pick one up and if it ends up not what i want i can always sell it. my shee is under the knife at the moment anyways. The whole assembly. Banshee cable with a hond thumb throttle. You might do some checking. I dont have any first hand experiance, just herd about guys running a honda thumb throttle. Quote Link to comment Share on other sites More sharing options...
