Thump ache
my thumb gets to the point where i cant even really ride anymore depending on the terrain. i mostly do trails though. an extended lever will help with this issue though?
Yea but it will also help you hold the throttle WOT. There was one on my banshee when I bought it. The tip of my glove on my index finger would catch the lever as my thumb would push it past. Let off with my thumb and my finger would keep the throttle held open.
hmm, i never thought of that. ill have to look into investing in one i suppose.
I took mine off because I didnt like it doing that. Longer lever requries a longer sweep so you will be pushing your thumb farther forward.
hmmm, i didnt even think of that. might try it anyways but is there a way to make it pull easier? i never had a problem on my ex gf's 400ex, so is there a possibility of greasing something and having it at least slide smoother because thats what i feel like mine is, more of a lever issue than from pulling the slides up.
I think you can use a honda thumb throttle. Try the 400 ex thumb throttle on your banshee. See how it fells. If it is good then buy one used off of ebay.
now are you talking about the whole assembly or just the lever? i might just pick one up and if it ends up not what i want i can always sell it. my shee is under the knife at the moment anyways.
The extended throttle levers lilke the ones cascade sell suck imho. they are ergonomically wrong and you end up pushing the throttle from the same point as stock if not further in. If you have stock carbs you can cut half a coil off the slide spring, if Keihns, get the soft springs from FAST. However, the best thing you can buy is the chariot performance adjustable throttle. With it you can adjust position at idle and it has an adjustable full throttle stop. It will also open carbs up to 41 mm i believe. I have put them on all my bikes.
The whole assembly. Banshee cable with a hond thumb throttle. You might do some checking. I dont have any first hand experiance, just herd about guys running a honda thumb throttle.
