dajogejr Posted December 14, 2010 Report Share Posted December 14, 2010 If you're putting it in the same set of cases and motor that trashed that vito's crank 3 times...no. If you're getting a whole new setup, it should....just like any other crank would. Quote Link to comment Share on other sites More sharing options...
lt1bird Posted December 24, 2010 Report Share Posted December 24, 2010 You using strieght cut gears with that tz bearing? Quote Link to comment Share on other sites More sharing options...
stroking Posted December 25, 2010 Author Report Share Posted December 25, 2010 You using strieght cut gears with that tz bearing? yes when i get the crank back. the new crank was not true so it had to be shipped back. Quote Link to comment Share on other sites More sharing options...
