bansheemann420 Posted November 28, 2010 Report Share Posted November 28, 2010 02 banshee needs a oil change clutchis slippin a little i heard of atf type f but idk what is it or where to get it from and price can someone help??? Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted November 28, 2010 Report Share Posted November 28, 2010 02 banshee needs a oil change clutchis slippin a little i heard of atf type f but idk what is it or where to get it from and price can someone help??? I'm pretty sure you can buy type F at just about... anywhere. I even think grocery stores carry it... walmart definitely... but I've always used this stuff. http://www.rockymountainatvmc.com/productDetail.do?navType=type&webTypeId=398&navTitle=Chemicals&webCatId=23&keyword=GEAR+OIL&prodFamilyId=11719 You'll need two. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted November 28, 2010 Report Share Posted November 28, 2010 If your clutch is slipping then changing the oil wont fix the problem. Ethire the clutch is miss adjusted, wore out, or you put the wrong oil in it. Quote Link to comment Share on other sites More sharing options...
Sandfrk33 Posted November 29, 2010 Report Share Posted November 29, 2010 Sorry, just had to comment on the thread title. Sounds like a pirate. AAARRRRRR Quote Link to comment Share on other sites More sharing options...
camatv Posted November 29, 2010 Report Share Posted November 29, 2010 you be a needing a 17melemeter wranch to change dat eairl wit Quote Link to comment Share on other sites More sharing options...
Sandfrk33 Posted November 29, 2010 Report Share Posted November 29, 2010 you be a needing a 17melemeter wranch to change dat eairl wit Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted November 29, 2010 Report Share Posted November 29, 2010 If your clutch is slipping then changing the oil wont fix the problem. Ethire the clutch is miss adjusted, wore out, or you put the wrong oil in it. good post. Quote Link to comment Share on other sites More sharing options...
