10mm cub piston to head clearance
drap660
My 10 mil Cub is 0.052" and 210 psi. I think I'm gonna tighten the squish a tad and lower compression before next year. My 78 mm bore Twister is at 0.048" It goes down to 0.042" if you check both sides of the piston at the same time. Flat top piston, though, if that matters. I've ran a 421 Cub at 0.038" and at 0.050" with the same results at the track.
