MikeNick Posted November 23, 2010 Author Report Share Posted November 23, 2010 this an ebay seller, or what? mabey these guys should be reported....kinda gives dynatek a bad name.. Yeah..Here's a link to them. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=250602739910&viewitem=&sspagename=STRK%3AMEWNX%3AIT Quote Link to comment Share on other sites More sharing options...
AKheathen Posted November 23, 2010 Report Share Posted November 23, 2010 Yeah..Here's a link to them. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=250602739910&viewitem=&sspagename=STRK%3AMEWNX%3AIT well if you are not the only guy this "accidentally" happened to, and they are trying to feed you bs, instead of making it rigt, then ebay should know about it..... Quote Link to comment Share on other sites More sharing options...
MikeNick Posted November 23, 2010 Author Report Share Posted November 23, 2010 well if you are not the only guy this "accidentally" happened to, and they are trying to feed you bs, instead of making it rigt, then ebay should know about it..... Not sure about that Heath. The guy from Dynatek said he knows them an they're are ok, just not informed on what my problem was. Dynatek makes plug wires I guess that is one wire with a plug on each end of it then you cut it in the middle yourself. Tech support guy thinks ebay guy was thinkin that...Either way he took care of it. Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted November 24, 2010 Report Share Posted November 24, 2010 im running a dyna coil and cdi, i didnt notice any difference with the coil, just that it was a shit load cheaper then a genuine one. Quote Link to comment Share on other sites More sharing options...
camatv Posted November 24, 2010 Report Share Posted November 24, 2010 those look like some junk ass autozone plug wires.. i make my own plug wires. the crimper is whats a bitch to find one that works good i use bulk solid core wire ( o'reilleys) and they also have 90Degree ends and i just make them fit just right. those straight long ends are wacko lookin i also use the NGK stockish style resistor plug ends that screw in just like stock. works great. Quote Link to comment Share on other sites More sharing options...
MikeNick Posted November 24, 2010 Author Report Share Posted November 24, 2010 those look like some junk ass autozone plug wires.. i make my own plug wires. the crimper is whats a bitch to find one that works good i use bulk solid core wire ( o'reilleys) and they also have 90Degree ends and i just make them fit just right. those straight long ends are wacko lookin i also use the NGK stockish style resistor plug ends that screw in just like stock. works great. You can just buy enough to make a set of wires? Never knew that. What's the part # on that NGK cap your using. Are the caps FAST sells resistor caps? Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted November 24, 2010 Report Share Posted November 24, 2010 You could always buy a couple MSD Superconductor coil wires. They are 18 inches long (might be a little to long). http://cgi.ebay.com/ebaymotors/MSD-8-5mm-Replacement-Coil-Wire-84039-_W0QQcmdZViewItemQQhashZitem56408cb0d6QQitemZ370450149590QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories Quote Link to comment Share on other sites More sharing options...
rubberneck Posted November 24, 2010 Report Share Posted November 24, 2010 Increased spark energy. It added about 2hp on the dyno. Snop have you ever dyonoed with a nology coil. I have the nology and hot wires sittin on the bench, been too lazy to put it on. Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted November 24, 2010 Report Share Posted November 24, 2010 Snop have you ever dyonoed with a nology coil. I have the nology and hot wires sittin on the bench, been too lazy to put it on. It is the same as the dyna. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted November 25, 2010 Report Share Posted November 25, 2010 I run a nology coil with hot wires. I didnt notice a huge change. It did seem to make it start easier though. A hoter spark never hurt though. Quote Link to comment Share on other sites More sharing options...
