forrest411 Posted November 12, 2010 Report Share Posted November 12, 2010 Anyone know the factory setting for the clicker on the rear shock? Quote Link to comment Share on other sites More sharing options...
bansheesrtoys Posted November 13, 2010 Report Share Posted November 13, 2010 turn it all the way one way and cunt the clicks all the way to the other way then set it in the middle, i think its likme 12 click not sure though. Quote Link to comment Share on other sites More sharing options...
VictorK Posted November 13, 2010 Report Share Posted November 13, 2010 Sorry for jackin your post in advance haha. Can someone explain what that clicker adjustment does? Quote Link to comment Share on other sites More sharing options...
bansheesrtoys Posted November 13, 2010 Report Share Posted November 13, 2010 well the one on the side of the shock is for comp. and that means the harder you set the slow it will comp , resulting in a stiffer ride. and visevesuse the softer you set it the softer the ride. amd the one on the bottom of the shock is for rebound, and that is how fast your shock is able to come back out.to much and it feels like it is throwing you off and not enough u will bottom out over whoops. Quote Link to comment Share on other sites More sharing options...
VictorK Posted November 13, 2010 Report Share Posted November 13, 2010 I knew about the knob but not the rebound. Now I have to figure out where to set it for a 200lb guy well the one on the side of the shock is for comp. and that means the harder you set the slow it will comp , resulting in a stiffer ride. and visevesuse the softer you set it the softer the ride. amd the one on the bottom of the shock is for rebound, and that is how fast your shock is able to come back out.to much and it feels like it is throwing you off and not enough u will bottom out over whoops. Quote Link to comment Share on other sites More sharing options...
bansheesrtoys Posted November 13, 2010 Report Share Posted November 13, 2010 the best way is to go one click at a time making it slower till you bottom out once though a set of whoops. then turn back one click. Quote Link to comment Share on other sites More sharing options...
