68chevyc10355 Posted November 12, 2010 Report Share Posted November 12, 2010 I am looking for some advice on a setup for some county fair drags for a 350 and below class. The distance will range from 180 to 200 feet typically, and will be run on dirt that seems to have quite a bit of clay. Sometime soon I am going to get different exhaust and will send my cylinders back to HJR for a heavy dune port (probably will run CPI or snipers depending on how they turn out). I am hoping for around upper 60’s to 70 hp when done. This is my only fourwheeler so I will not being turning it into a drag bike, I just want to do decent at the drags and really well against the occasional 450. I am not sure where to go with tires. I have skat traks, razrs, and access to flat track tires, but can buy others if need be. Should I strap my suspension down? I was considering 18 or 19 cc domes with plus 6 timing or so (my altitude is about 900 ft and I will run 113 oxy fuel). For gearing I was thinking a 15 or 16t front sprocket and leaving in 2nd. Also, I weigh 170 lbs. Anyone who has already played with this kind of setup please guide me in the right direction. Quote Link to comment Share on other sites More sharing options...
1bad450r Posted November 12, 2010 Report Share Posted November 12, 2010 I am looking for some advice on a setup for some county fair drags for a 350 and below class. The distance will range from 180 to 200 feet typically, and will be run on dirt that seems to have quite a bit of clay. Sometime soon I am going to get different exhaust and will send my cylinders back to HJR for a heavy dune port (probably will run CPI or snipers depending on how they turn out). I am hoping for around upper 60’s to 70 hp when done. This is my only fourwheeler so I will not being turning it into a drag bike, I just want to do decent at the drags and really well against the occasional 450. I am not sure where to go with tires. I have skat traks, razrs, and access to flat track tires, but can buy others if need be. Should I strap my suspension down? I was considering 18 or 19 cc domes with plus 6 timing or so (my altitude is about 900 ft and I will run 113 oxy fuel). For gearing I was thinking a 15 or 16t front sprocket and leaving in 2nd. Also, I weigh 170 lbs. Anyone who has already played with this kind of setup please guide me in the right direction. Get yourself a set of good pipes first, those t6's suck serious pole for ported motors. Quote Link to comment Share on other sites More sharing options...
banshee(911) Posted November 27, 2010 Report Share Posted November 27, 2010 I would say get a set of prowedges or some 4 snows try to strutt the rear and play wth gearing..I run 14/44 for 300 feet.hope this helps Quote Link to comment Share on other sites More sharing options...
