Carb tuning
sootman73
Trying to fgure out how to tune the carbs. What i have is a high idle and it was set just fine after the carbs were rebuilt. a couple days later its hard to start then keep running until its warmed up. I have the air screw turned out 1 on both sides. Also when i pull the choke out it revs up. :confused: i had it idling and i sprayed carb cleaner around every joint that i could think of to see if there was an air leak. nothing i used a whole can so if there was a leak it woulda found it. Any ideas why the thing revs up when i pull the choke out?
