hick01 Posted November 3, 2010 Report Share Posted November 3, 2010 (edited) I got an 01 banshee about a month ago and this is one of my first post I did a complete rebuild on the motor because crank was ba when I got it I put in stock 64 mm Wiseco pistons, all new seals, I also got a t5 pipe and a k&n air filter I put a 300 main jet in the problem is it won't start when it's been sitting I can kick 100 times it will seem like it's going to start but dosent if I push start it it fires right up. It has tons of power every were. I checked the plugs and they were a dark grey. After its hot starts up first kick. Help please Edited November 3, 2010 by hick01 Quote Link to comment Share on other sites More sharing options...
tripledsracing Posted November 3, 2010 Report Share Posted November 3, 2010 I got an 01 banshee about a month ago and this is one of my first post I did a complete rebuild on the motor because crank was ba when I got it I put in stock 64 mm Wiseco pistons, all new seals, I also got a t5 pipe and a k&n air filter I put a 300 main jet in the problem is it won't start when it's been sitting I can kick 100 times it will seem like it's going to start but dosent if I push start it it fires right up. It has tons of power every were. I checked the plugs and they were a dark grey. Help please fatten up your pilot! Quote Link to comment Share on other sites More sharing options...
tripledsracing Posted November 3, 2010 Report Share Posted November 3, 2010 maybe turn your air screw in a turn if you dont have any pilot jets!..what pilot you runnin? Quote Link to comment Share on other sites More sharing options...
hick01 Posted November 3, 2010 Author Report Share Posted November 3, 2010 (edited) Ok Ill try that should I change witch grove my needle is in I'll check my pilot it's what ever is stock Edited November 3, 2010 by hick01 Quote Link to comment Share on other sites More sharing options...
dirtbike drew Posted November 4, 2010 Report Share Posted November 4, 2010 Make sure you have your black choke tube between the two carbs. I for got to put mine in the other day and it would only push start. Quote Link to comment Share on other sites More sharing options...
hick01 Posted November 4, 2010 Author Report Share Posted November 4, 2010 Ya the black tube between the carbs is there Quote Link to comment Share on other sites More sharing options...
