  • Replies 56
  • Created
  • Last Reply
Top Posters In This Topic
Hi Jeff. Do you guys do a 7mm kit? Kit consisting of: Barrels, Head, Special cut domes, pistons, plugs, stud extenders and gaskets. Would you recommend larger carbs and high flow pipes for these?
Not trying to steal Jeff's thunder, but they don't offer this cylinder cast for a 7mm crank, at this time it's stock stroke and 4mm only.
That being said, that's up to Jeffro if he/you wanted to port the 4mm version to work with the 7 mil.
Calvin says they will not offer the Serval in anything but stock stroke and 4mm stroke. Just wont be much demand for a 7mm Serval when the Cubs do so well. The Serval is a bolt on kit to help fill the void for Duners/Play bikes who dont want light switch (as some refer to as Cub powerband) power without going full Race Cub.
Wampus 4mm and 10mm will be available within a week or so. They will also be available with the 4mm serval port layout soon.
The 7mm will be down the road a bit. We or any CP ind. dealer can get them for you. The Wampus is available in 68mm and 72mm bore.
Will the Wampus be in 7mm with the Serval's port timings?? Then I will rather wait for them if so.... Any idea on pricing yet, or any more info will be appreciated?
I understand this will be a stock look alike cylinder, but what else?
Thanks
Edited by 2strokespirit
The 72mm Wampus will use the Supercub head/domes OR soon Calvin is working on a stock head look alike with Supercub layout. Yes the Wampus cyl. will be available in a 7mm Serval layout but it will be about a month or so. Retail pricing on the Wampus is $1,075 plated.
Soo, what you are saying is, the wompus will have the same port layout as the servals ..triple transfer - triple exhaust - bridged intake with the mellow timings of the serval and will appear completely stock on the outside ???
yup thats what hes saying...the only difference so far is that its one piece like the cubs. itll be interesting to see how close they look like stock. is that price tag for only cylinders plated? they must be :notworthy::notworthy::notworthy::notworthy::notworthy:
