No Limit Powersports Posted November 3, 2010 Report Posted November 3, 2010 Ok guys for all of you that dont want to do a crank but want a Serval its now available. They are a 68x54 = 392cc no case work needed just bolt on and go! I got 2 of them in stock if anybody is interested. If you are using a 110mm rod (stock) a 9768m06800 piston will be used or if your using a 115mm rod a blaster piston can be used. Prices start at 798 for the cylinder. Packages available. Let me know Andy Quote
68chevyc10355 Posted November 9, 2010 Report Posted November 9, 2010 Ok guys for all of you that dont want to do a crank but want a Serval its now available. They are a 68x54 = 392cc no case work needed just bolt on and go! I got 2 of them in stock if anybody is interested. If you are using a 110mm rod (stock) a 9768m06800 piston will be used or if your using a 115mm rod a blaster piston can be used. Prices start at 798 for the cylinder. Packages available. Let me know Andy Any numbers on how hard they run for the stock stroke? Quote
Keyser Soze Posted November 11, 2010 Report Posted November 11, 2010 Does that come with pistons and domes? Quote
No Limit Powersports Posted November 11, 2010 Author Report Posted November 11, 2010 798 is just the cylinder. Pistons price will vary if your running 110mm rod or 115mm rod. Quote
zachass9 Posted November 12, 2010 Report Posted November 12, 2010 OH ME, OH ME!! Any dyno numbers yet LOL maybe need a test DUMMY? Definately thinking Calvin has hit the jackpot in the duner world with these Servals!! I was so impressed with the performance of the 421 Serval that I rode, I cant wait to see what kind of performance and dyno numbers this lil 393 throws down!! I just might have to do one on the duner build I just started! Quote
