What is the best way to remove the tors and the lights from my harness? do i just cut the wires from the connectors and just get rid of the wires and ground wires for the lights and tors? or do i have to save some of them to make the bike run? i read the entire electrical sticky above but its still not too clear to me. also what is the best way to remove the key switch? sorry, im not too good with wiring, never really understood any of the terms too well. help me out guys. Thanks
-Ryan
Edited by shoopie
The only wires you need are the orange and black wires to go to the coil; then another black wire to ground. Put the black/white wire inline with your tether kill switch. I think you ground the black/red wire also; but don't remember for sure.
i dont have a tether. i have lightswitch kill and key switch.
Edited by shoopie
you need all the stator wires, except yellow. keep all the black wires, except where it goes to pigtails that you won't use. you can trim all the stuff off the black/white wire, just a strait connection to the killswitch. the orange coil wire is needed, and the red/black wire needs to be grounded to black.
Connections:
Ignition = RED + RED/BLACK
Coil = ORANGE (+) & BLACK (-)
Voltage Reg = BLUE + BLACK [To Frame Gnd]
CDI:
WHITE/GREEN > STATOR (WHITE/GREEN)
WHITE/RED > STATOR (WHITE/RED)
GREEN > STATOR (GREEN)
RED > STATOR (RED)
RED/BLACK > IGNITION (RED/BLACK)
BLACK/WHITE > KILL SWITCH (BLACK/WHITE)
BLACK > WIRING GRD (BLACK)
ORANGE > IGN COIL (ORANGE)
Stator:
YELLOW > VOLTAGE REG (YELLOW) & DIMMER SWITCH (YELLOW/RED)
Do Not Connect (Open Circuit -OR- Tether Switch):
Kill Switch = BLACK/WHITE + BLACK
Removable T.O.R.S. Junk:
Control Unit = YELLOW/BLACK + BLACK + BLACK/WHITE
Throttle switch = BLACK + BLACK/YELLOW
Carb Switch A = BLACK/YELLOW + YELLOW/BLACK
Carb Switch B = YELLOW/BLACK + BLACK
Lighting:
Headlights = GREEN + YELLOW + BLACK
Taillight = BLUE + BLACK
Connections:
no
the red/brown are unused in the switch harness. those are functions on another atv, that uses the same switch....most likely ignition power for actuators and such. it's easiest to ground the red/black close to the cdi plug to keep things simpler, if you never plan on using the function on that harness.
no
Good catch that should read: Ignition = BLACK + RED/BLACK
