VooDooBanshee Posted October 26, 2010 Report Share Posted October 26, 2010 Hey guys- Will a set of works shocks for a blaster fit a banshee? Will I loose any ground clearence? Thanks! Quote Link to comment Share on other sites More sharing options...
VooDooBanshee Posted October 26, 2010 Author Report Share Posted October 26, 2010 The guy says they are 15 inch from eye to eye and were on extended blaster a-arms.... Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted October 26, 2010 Report Share Posted October 26, 2010 I know on Blaster Forum they say 'shee shocks are upgrade with out mod, Worsecase is spring rate may be little soft. Have to compare length for ground clearance. If price is right snag them, can always resell if you don't like them Quote Link to comment Share on other sites More sharing options...
VooDooBanshee Posted October 27, 2010 Author Report Share Posted October 27, 2010 I know on Blaster Forum they say 'shee shocks are upgrade with out mod, Worsecase is spring rate may be little soft. Have to compare length for ground clearance. If price is right snag them, can always resell if you don't like them Anyone else have any luck on this configuration? Quote Link to comment Share on other sites More sharing options...
banshee67 Posted October 31, 2010 Report Share Posted October 31, 2010 just do it. i was wanting to do something like that to try to lower it for flat track. that would be for stockers thought. idk about extended works though Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted November 1, 2010 Report Share Posted November 1, 2010 Stock 'shee shocks are 14 3/4 , so you should be good to go. Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted November 1, 2010 Report Share Posted November 1, 2010 (edited) The springs and valving are going to be to soft for a Banshee. A Blaster is about 50 pounds lighter than a Banshee, does not have the power and speed of a Banshee, and most Blaster riders do not weigh as much, nor are as aggresive as Banshee riders. If a Banshee shock is an upgrade on a Balster, that tells me that a Blaster shock on a Banshee is a downgrade. Edited November 1, 2010 by bansheesandrider Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted November 1, 2010 Report Share Posted November 1, 2010 The springs and valving are going to be to soft for a Banshee. A Blaster is about 50 pounds lighter than a Banshee, does not have the power and speed of a Banshee, and most Blaster riders do not weigh as much, nor are as aggresive as Banshee riders. If a Banshee shock is an upgrade on a Balster, that tells me that a Blaster shock on a Banshee is a downgrade. The "banshee upgrade" they are referring to, is stock-for-stock swap. Works uses a progressive valving setup, rather than static valving. a 50lb difference won't be noticeable to 95% of riders as far as the valving is concerned. Being under-sprung is a possibility, but odds are the person who ran them on a blaster, ran them on extended a-arms, so they would be sprung heavier than stock. In my professional opinion, I think you would be happy running those shocks over stock. Quote Link to comment Share on other sites More sharing options...
