power valve
james350b
The power valve is like haveing a varable hight exhaust port. The higer the exhaust port the more hp you can build but it will be at a high rpm. A high exhaust port causes a poor midrange. So you have this valve the closes the exhaust port and lowers the port hight. It gives a good mirange. As the RPMs raise the valve raises, raising the exhaust port wich give a better top end.
It allows an agressivly ported cylinder (Like a Drag Port) a stronger midrange. Something that isnt achievable by porting alone.
The Trinity Cheeta is the most common power valve cylinder. The Cheeta cub is its baby brother with no powervalve.
