NYCBanshee7 Posted October 12, 2010 Report Share Posted October 12, 2010 (edited) Whats up guys, I was attempting to change the swingarm bearings but failed to remove the swingarm because the main swingarm pivot bolt is frozen/seized to the spacer sleeve inside and is impossible to remove. I tried everything. I was able to cut the bolt on the chain side without hurting the swingarm. When I tried to cut the side of the kickstarter, there isn't enough clearance for the blade. I'm going to have to cut the swingarm and replace it. Anyone have this problem or can advise me the best way to cut the swingarm??? Thanks alot, Eric Edited October 13, 2010 by NYCBanshee7 Quote Link to comment Share on other sites More sharing options...
NYUK Posted October 13, 2010 Report Share Posted October 13, 2010 sometimes u can beat the swinger bolt and sleeve over enough to cut the bolt, the bolt cuts like butter, the sleeve will take a pack of sawzall blades, i have a bolt and a pile of swingarms. 40 and shipping for a swingarm, bolt and sleeve, call john 215 880 1990. or pm me.or come pick it up sun, i am at exit 3 of the nj trnpk. Quote Link to comment Share on other sites More sharing options...
NYCBanshee7 Posted October 13, 2010 Author Report Share Posted October 13, 2010 Thanks NYUK, but i even beat the shit out of it with a punch and a sledge and I just can seem to get enough clearance for a blade between the frame and the arm on the kickstarter side. I went through 3 blades on the left side which was no big deal but having trouble with the right side. Any way to cut throught the swingarm, bolt and sleeve? Torch? Quote Link to comment Share on other sites More sharing options...
NYUK Posted October 13, 2010 Report Share Posted October 13, 2010 i just wack them off with an angle grinder with a cut wheel. Quote Link to comment Share on other sites More sharing options...
STINKYDELUXE Posted October 14, 2010 Report Share Posted October 14, 2010 My swing arm bolt was stuck it wouldn't move either way and I used the snap-on 3050 (air hammer)and it cam right out in about 5 seconds. Quote Link to comment Share on other sites More sharing options...
AZMarine Posted October 14, 2010 Report Share Posted October 14, 2010 I had the same problem with my new-to-me banshee last week and an air hammer made short work of that bolt. I beat the isht out of it with a sledge and punch, then a 3/8 extension. The air hammer knocked it out in seconds. Quote Link to comment Share on other sites More sharing options...
