bad 350 shee Posted October 9, 2010 Report Share Posted October 9, 2010 well my bike shifts hard as fuck with a load on it i was wanting to try out a pancake bearing and get the shift star modded will i benefit from this? Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted October 9, 2010 Report Share Posted October 9, 2010 pancake bearing helps to prevent the ball and rod from welding together. Those push the pressure plate out on the clutch. The modded shift star makes the transmission find the gears a little easier. The bushing/bear goes into the dips of the star easier. Shift star will help a little. There's also the shift pro shift kit. It makes the shifter easier to go up and down. I had both and still hated it. Ended up going with an override. Quote Link to comment Share on other sites More sharing options...
badassbanshee479 Posted October 28, 2010 Report Share Posted October 28, 2010 hit up kevin over at herr jugs.... I hear he is modding shee transmissions to make them shift better without going full over ride. Quote Link to comment Share on other sites More sharing options...
camatv Posted November 1, 2010 Report Share Posted November 1, 2010 i do the trans mod also. i called it a MX trans back in the day works well. all you will need is a shift star mod and the dogs cut, all the other stuff is gimick. Quote Link to comment Share on other sites More sharing options...
