banshee9090 Posted November 24, 2010 Author Report Share Posted November 24, 2010 hmmm Quote Link to comment Share on other sites More sharing options...
Vintage Smoke Posted November 24, 2010 Report Share Posted November 24, 2010 AK reccomended an octane rating for the compression you are running. Keep in mind that different countries calculate octane differently!! You may have to do some math to convert US octane ratings to what your country uses. Quote Link to comment Share on other sites More sharing options...
banshee9090 Posted November 24, 2010 Author Report Share Posted November 24, 2010 (edited) AK reccomended an octane rating for the compression you are running. Keep in mind that different countries calculate octane differently!! You may have to do some math to convert US octane ratings to what your country uses. thanks man about u comment ,anyhow i can not find more than 95 octane in my country , i think no bigdeal between 95 octain in saudi araba and 98 octain in us! , octain calclation is international Edited November 24, 2010 by banshee9090 Quote Link to comment Share on other sites More sharing options...
AKheathen Posted November 24, 2010 Report Share Posted November 24, 2010 can you get a hold of av gas? 100LL works awesome Quote Link to comment Share on other sites More sharing options...
tedd1 Posted November 24, 2010 Report Share Posted November 24, 2010 thanks man about u comment ,anyhow i can not find more than 95 octane in my country , i think no bigdeal between 95 octain in saudi araba and 98 octain in us! , octain calclation is international Read >HERE< Quote Link to comment Share on other sites More sharing options...
banshee9090 Posted November 25, 2010 Author Report Share Posted November 25, 2010 (edited) thanks guys for the kind help as i said earlier i have no choice ,95 octane!is the higher octane in my place Edited November 25, 2010 by banshee9090 Quote Link to comment Share on other sites More sharing options...
AKheathen Posted November 25, 2010 Report Share Posted November 25, 2010 if you cannot at least get avgas from the airport, then i hate to say, that you need to decrease compression Quote Link to comment Share on other sites More sharing options...
banshee9090 Posted November 26, 2010 Author Report Share Posted November 26, 2010 if you cannot at least get avgas from the airport, then i hate to say, that you need to decrease compression AK u useful help for banshee hq members is highly appreciate, if u can advice what is the safe compression to be used for (gas 95 octane),another way to what reading i need to decreas compression? Quote Link to comment Share on other sites More sharing options...
banshee9090 Posted November 26, 2010 Author Report Share Posted November 26, 2010 AK u useful help for banshee hq members is highly appreciate, if u can advice what is the safe compression to be used for (gas 95 octane),another way to what reading i need to decreas compression? pleas note i run stock timing! Quote Link to comment Share on other sites More sharing options...
Darthwall Posted November 26, 2010 Report Share Posted November 26, 2010 at that comp I would say get different domes lower it to 165 and lower run your gas once jetting is looking good Quote Link to comment Share on other sites More sharing options...
AKheathen Posted November 26, 2010 Report Share Posted November 26, 2010 ok 3 things....first, check to see how the octane is rated.....it should say something at the pump about it. here, they say "(R+M)/2" that would set weather you should be running 23, or 24cc domes.....keep in mind, that it will lower compression if you move to cylinders with smaller bore, adn increase compression as you move to lower elevation, and when the rings seat. second, check your compression gauge. make sure the end of it where it screws into the cylinder is the same length as the spark pug (br8) and that it has the valve at the very tip. stock compression should be around 125psi sea level, and yours read 145? @2200'. it is possible that your gauge is reading high. third, it is a good idea to do a leak-down test on the top-end..... Quote Link to comment Share on other sites More sharing options...
banshee9090 Posted November 27, 2010 Author Report Share Posted November 27, 2010 since u guys recommend that wonderful advice I shift to the stock cool head , went to the sand , pull it 1st to 6th gear , the power created by the new setup looks ok, no bog, no over temp and no problems, this week I will race with other motors , in order to evaluate new setup and to see if there is need to put more power on it. I will tray to video that.thanks guys. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted November 27, 2010 Report Share Posted November 27, 2010 how did you go about running the stock head? is it recessed the extra 1.5mm for proper clearance? also, the stock head chambers range from 22cc to 25cc, which you can only tell by measuring them with fluid. it is possible, as i mentioned, that you are getting high readings from the 22+2 domes. what did that stock head kick out anyways? Quote Link to comment Share on other sites More sharing options...
banshee9090 Posted November 28, 2010 Author Report Share Posted November 28, 2010 (edited) how did you go about running the stock head? is it recessed the extra 1.5mm for proper clearance? also, the stock head chambers range from 22cc to 25cc, which you can only tell by measuring them with fluid. it is possible, as i mentioned, that you are getting high readings from the 22+2 domes. what did that stock head kick out anyways? Actually hot rod company recommend to use 4mil +5 crank shaft with Stroker gasket under stock cool head part# G093 , </SPAN> so far That is ok i will make sure about the setup after i race withe the guys hear in my place and beat them all , stock cool head kick if i still remember between 140 -150 psi yes it is possible to measure cool head chamber with fluid ! Edited November 28, 2010 by banshee9090 Quote Link to comment Share on other sites More sharing options...
banshee9090 Posted December 11, 2010 Author Report Share Posted December 11, 2010 since u guys recommend that wonderful advice I shift to the stock cool head , went to the sand , pull it 1st to 6th gear , the power created by the new setup looks ok, no bog, no over temp and no problems, this week I will race with other motors , in order to evaluate new setup and to see if there is need to put more power on it. I will tray to video that.thanks guys. I raced yesterday at dune, my banshee beat all the way raptor of my friend 660cc with trinity stage pipe , not sure what sport air filter he use and how big his carburetor jet ,according to him he upgrade his bike in household builder workshop ,that was my first time racing and we were surprised all that fast incremental horsepower for the new banshee setup so guys I m happy with my shee now I told him about the wonderful banshee hq forum and how helpful is that. Quote Link to comment Share on other sites More sharing options...
