joee20002 Posted October 5, 2010 Report Share Posted October 5, 2010 Ok this is what i have. Stock 06 shee with t5 pipes and pwk 28 carbs.. I just pulled the stock carbs off and the parking brake BS.. All i did was just un plug everything. Now my left cylinder will not fire? Do i need to clip any wires from the tors? I flipped the spark plug wires and still same problem... Quote Link to comment Share on other sites More sharing options...
baze143 Posted October 6, 2010 Report Share Posted October 6, 2010 i just did the same thing and i found out that it was because of the parking brake, its an overide that is sensing the parking brake is engaged and it cut power to the motor. what you have to do is either cut the wire or just unplug the swtch and that fixed mine hopefully someone else will chime in and explain the technical side to it all Quote Link to comment Share on other sites More sharing options...
joee20002 Posted October 6, 2010 Author Report Share Posted October 6, 2010 do i need to clip some wires or twist some together? Quote Link to comment Share on other sites More sharing options...
joee20002 Posted October 6, 2010 Author Report Share Posted October 6, 2010 turns out its the one carb but i cleaned the crap out of it an still wont fire.. what caan be bad in a carb? im stumped... Quote Link to comment Share on other sites More sharing options...
