Got an 03 ram 1500 quad cab hemi and the passengers windows won't go down with their window buttons. But I can put all 4 down with the driver side controls.
No the window lock isn't on. I've tried pushing it on and off countless times and the passenger switches won't roll them selves down. I've gotten them to work once but then a few days later I get nothing. Anyone got any ideas?
Replace the passenger side switch, simple as that.
When you take the door off, get a 12 volt tester and make sure you are getting power to the switch, after that...replace it.
OEM dealer is probably the only place you can go for that, it can't be too much.
Trade it in on a Ford J/K. It's just the switch most likely as daj said should be a easy fix.
  • 4 weeks later...
