Kick start question
wkayler
Just replaced my clutch basket and shifter oil seal and i took my kick start gear off. Now im having trouble getting it to work right. Ive tried for 2 or 3 hours to get it in correct and all it does is turn the motor half way over and the spring wont pull it back up unless i wiggle it a litte bit. Cant get it to fire or function properly. I know its probablt a retarded question but im new to working on banshees so take it easy on me.
Clymers manual is your friend. To many steps for me to try to explain. Spring on gear faces away from gear , straight end of spring goes in slot , Gear spring goes into half moon slot on case ,kick stop arm goes slightly CCW of gear spring , use needle nose pliers turn return spring clocwise hook on spring post. Pages 164 -170. Your results may vary.
