VictorK Posted October 1, 2010 Report Share Posted October 1, 2010 my current motor set up is, standard 20cc domes, welded stock crank, and hjr port for my t5s. Do I only need new domes or does the porting need to be changed? Also what would the difference be and how drastic? Quote Link to comment Share on other sites More sharing options...
Nutwood 472 Posted October 1, 2010 Report Share Posted October 1, 2010 my current motor set up is, standard 20cc domes, welded stock crank, and hjr port for my t5s. Do I only need new domes or does the porting need to be changed? Also what would the difference be and how drastic? yep,porting need changed and you need new domes cut for a sleeper engine,and ther will be a noticable difference and a little more torque. Quote Link to comment Share on other sites More sharing options...
06specialedition Posted October 1, 2010 Report Share Posted October 1, 2010 I rode two differant Wildcard shee's and the 4 mil rips hard Faster than my ported stock 350 Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted October 1, 2010 Report Share Posted October 1, 2010 Yep that is what sucks about going from a ported stock stroke to a ported 4 mill. You have to get new cylinders and have them reported. I am sure your cylinders have had the port hights raised to much for them to be corrected for a 4 mill crank. When they port for a 4 mill the start by lowering the ports roughly 2mm since the piston falls 2mm down in the bore. Then they raise the roof's of the ports. Since your ports have already been raised when the drop the floor's 2mm the ports are way to big and to far advanced. Quote Link to comment Share on other sites More sharing options...
VictorK Posted October 1, 2010 Author Report Share Posted October 1, 2010 I was just curious. I think next year I might do cheetah cub cylinders. For around here my hjr ported cylinders are the fastest thing around but I have this power and wonder how much fun a cub would be. I still have stock carbs, which I think a upgrade to better carbs along with a lockout and higher compression domes would be a good difference. Maybe that would do it for me. Quote Link to comment Share on other sites More sharing options...
Burt Reynolds Posted October 1, 2010 Report Share Posted October 1, 2010 Lets see here,you will need the 4mil crank. port work. head work bigger carb setup ect ect ect Quote Link to comment Share on other sites More sharing options...
bansheesrtoys Posted October 2, 2010 Report Share Posted October 2, 2010 i did a +4 with 110 rods as a sleeper with 19 domes stock port and carbs, useing a spacer plate to rasie the jugs, it is the fastest quad around where i go riding. and yes i know porting it and carbs will make it faster, but the way i have it set up its fast, plus it not cheap to go fast. Quote Link to comment Share on other sites More sharing options...
MacRacer1 Posted October 4, 2010 Report Share Posted October 4, 2010 4 mils rip! Quote Link to comment Share on other sites More sharing options...
