KENDOE Posted September 29, 2010 Report Share Posted September 29, 2010 what are the benefits 2 the T.O.R.S delete?? is there really any gain on power/fuel efficiency?? or is it just the convenience of having more room around the motor and a little less weight?? Quote Link to comment Share on other sites More sharing options...
12 0 Clock P I M P Posted September 29, 2010 Report Share Posted September 29, 2010 Its neither..................................the T.O.R.S. system will eventually have you chasing a problem........it is known to cause problems with your shee running right............................................like sputter..not revving out............................etc.............................it is design to protect the engine from overreving....................................he.nce the name Throttle Over Ride System The benefit is you will not have any issues as above with removing the tors...its worthless and takes up a shitload of space................................................. so an added bonus is the more room and you have the peace of mind of knowing something is actually wrong when its not running right...........................................Its the first thing i would do to any shee The tors is not wort anything to anyone here............................................so toss it in the scrapyard Quote Link to comment Share on other sites More sharing options...
06specialedition Posted September 29, 2010 Report Share Posted September 29, 2010 IMHO its a must for any banshee. Get that shit off there Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted September 29, 2010 Report Share Posted September 29, 2010 Do other brands use a tors? Or other Yammies other than 'Shee and Blaster? Just looked at the Warrior ,no wires at throttle ,couldn't really see carb well enough. Quote Link to comment Share on other sites More sharing options...
rockenshee Posted September 30, 2010 Report Share Posted September 30, 2010 what are the benefits 2 the T.O.R.S delete?? is there really any gain on power/fuel efficiency?? or is it just the convenience of having more room around the motor and a little less weight?? removing the tors makes it a lot easyer to sync you carbs and tune it Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted September 30, 2010 Report Share Posted September 30, 2010 TORS can be DISABLED by just unplugging the little black box under the left side of the fuel tank next to the coil, nothing else needs to be done to disable it. The delete kits get rid of the funky carb tops and make it easier to work on the carbs. Quote Link to comment Share on other sites More sharing options...
fastquad02blaster Posted October 1, 2010 Report Share Posted October 1, 2010 A lot of other things run that crap. I think yamaha uses it extensively on all their stuff. Yfz 450s have it. My buddy's little switch on the handle bars was bad and it took some major brain power to figure that one out. Quote Link to comment Share on other sites More sharing options...
