ballsdeep Posted September 24, 2010 Report Share Posted September 24, 2010 what needs to be done to a stock motor to add straight pipes? Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted September 24, 2010 Report Share Posted September 24, 2010 what do you mean by "straight" pipes? Please explain. Quote Link to comment Share on other sites More sharing options...
ballsdeep Posted September 24, 2010 Author Report Share Posted September 24, 2010 what do you mean by "straight" pipes? Please explain. exhauste pipes....... drag pipes Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted September 24, 2010 Report Share Posted September 24, 2010 Whatever pipes you put on, MAKE SURE THEY HAVE SILENCERS! Even drag pipes use silencers, and the ATV segment has enough morons doing things like riding where they shouldn't, hit and run, and loud pipes that give us a bad name. We are continuously fighting for land to ride on and the big complaints are noise and damage to plants and land.Everybody needs to do their part and keep their bikes quiet. It does not do any good to have mega power if there is no place to use it. Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted September 24, 2010 Report Share Posted September 24, 2010 Do you realize that if you put straight pipes on a stock motor, the porting isn't going to match the pipe's power range. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted September 24, 2010 Report Share Posted September 24, 2010 I don't even run pipes on my banshee. I just want it loud and don't care how it runs. Quote Link to comment Share on other sites More sharing options...
bbcmudtruck Posted September 24, 2010 Report Share Posted September 24, 2010 ^^^^^^^^ haha ^^^^^^^^^^ Quote Link to comment Share on other sites More sharing options...
AKheathen Posted September 24, 2010 Report Share Posted September 24, 2010 hahahaha, these are 2-strokes....the pipes are actually like turbos. the shape stuffs the cylinders with a return pulse at and near certain rpm range. the silencers keep it tuned efficiently. without them, you loose power from lack of back-pressure. even removing the packing robs some power. that being said- if you want to run drag pipes, you are going to need drag porting, and build it around that. you will basically have shit for mid and bottom, which will make it hard/unpleasant to ride anywhere but the strip. Quote Link to comment Share on other sites More sharing options...
fastquad02blaster Posted September 24, 2010 Report Share Posted September 24, 2010 I would say that's why some drag guys go with power valved jugs. For that little bit extra bottom end that they loose. Quote Link to comment Share on other sites More sharing options...
ballsdeep Posted September 24, 2010 Author Report Share Posted September 24, 2010 Do you realize that if you put straight pipes on a stock motor, the porting isn't going to match the pipe's power range. no i dont realized that. thats why im asking because im new to the banshee scene! Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted September 24, 2010 Report Share Posted September 24, 2010 (edited) Do you realize that if you put straight pipes on a stock motor, the porting isn't going to match the pipe's power range. For all I knew he was talking about "straight" pipes without "chambers", ala 4 poker , lol. Also a 2 stroke will run with no pipe, "straight" pipe , any pipe (expansion chamber) , but it will only run correctly (best) with the correct pipe for how the engine is ported. I agree with you that drag pipes do look sweet. Edited September 24, 2010 by Larry's Shee Quote Link to comment Share on other sites More sharing options...
Hilarious Posted September 24, 2010 Report Share Posted September 24, 2010 A stocker with all the bolt on stuff will run decent with a set of inframe CPIs. You wont get the full potential of that pipe without some portwork but it will run pretty decent. Quote Link to comment Share on other sites More sharing options...
ballsdeep Posted September 25, 2010 Author Report Share Posted September 25, 2010 A stocker with all the bolt on stuff will run decent with a set of inframe CPIs. You wont get the full potential of that pipe without some portwork but it will run pretty decent. i already have that Quote Link to comment Share on other sites More sharing options...
06specialedition Posted September 26, 2010 Report Share Posted September 26, 2010 A stocker with all the bolt on stuff will run decent with a set of inframe CPIs. You wont get the full potential of that pipe without some portwork but it will run pretty decent. X2... I run CPI Inframe Drag Pipes and with my Wildcard Racing port work these pipes rip! On a more stock motor T'5 and PC's run awesome. Quote Link to comment Share on other sites More sharing options...
06specialedition Posted September 26, 2010 Report Share Posted September 26, 2010 i already have that You already have CPI's?!?!?...Unless your bike is already ported, IMHO you still can pull more power out of these pipes with more motor work. You need a decent build for OOF drag pipes Quote Link to comment Share on other sites More sharing options...
