lawngod Posted September 21, 2010 Report Share Posted September 21, 2010 i have read all the talk about this job . Some guys say i can do it by just taking off the lower half. but about the cluch and the bearing plate. can you guys please give me a step bye step to do this. thanks for all the help , iam happ y to see all the shee freaks out there. Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted September 21, 2010 Report Share Posted September 21, 2010 So your wanting to just replace the lower case? Or just get in there and fix/change something without taking the top end off? Quote Link to comment Share on other sites More sharing options...
lawngod Posted September 21, 2010 Author Report Share Posted September 21, 2010 So your wanting to just replace the lower case? Or just get in there and fix/change something without taking the top end off? yes that is it ... im a ex B.C boy (Abbotsford ) Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted September 21, 2010 Report Share Posted September 21, 2010 Nothing like makeing it a pain to save 2 base gaskets. Quote Link to comment Share on other sites More sharing options...
lawngod Posted September 21, 2010 Author Report Share Posted September 21, 2010 Nothing like makeing it a pain to save 2 base gaskets. i have a new full gasket kit Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted September 21, 2010 Report Share Posted September 21, 2010 So what exactly are you wanting to do inside? You will still have to take off the clutch, bearing plate and the timing plate also ether way you go about splitting. Quote Link to comment Share on other sites More sharing options...
lawngod Posted September 22, 2010 Author Report Share Posted September 22, 2010 So what exactly are you wanting to do inside? You will still have to take off the clutch, bearing plate and the timing plate also ether way you go about splitting. just to replace the cracked case Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted September 22, 2010 Report Share Posted September 22, 2010 It's always best to replace them as a set. There cast as a set from Yamaha. Not saying you cant, but it's best to do them as a set. You ever split the cases before? Quote Link to comment Share on other sites More sharing options...
lawngod Posted September 22, 2010 Author Report Share Posted September 22, 2010 (edited) It's always best to replace them as a set. There cast as a set from Yamaha. Not saying you cant, but it's best to do them as a set. You ever split the cases before? i have a got a set of cases why is it the best to keep them together.i have split the case on 2 or 3 blasters Edited September 22, 2010 by lawngod Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted September 22, 2010 Report Share Posted September 22, 2010 There cast as a set. Like i said you can do it, but if it were me i would replace together. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted September 22, 2010 Report Share Posted September 22, 2010 i have a got a set of cases why is it the best to keep them together.i have split the case on 2 or 3 blasters You can take them appart and put them back to gether fine. You just dont want to mix and match case halfs. The top and bottom haves are a set. Yamaha bolts them together and finish bores / line hones all the bearing surfaces / bores. If you mix and match the cases you might end up with to tight or to loose of a bearing clearance. Quote Link to comment Share on other sites More sharing options...
