wheredahoesatracing Posted September 20, 2010 Report Share Posted September 20, 2010 can anyone help me i am trying to find some oversized stock carb bowls for my bike its on alcohol and i am afraid its gonna run out on long pulls!!! Quote Link to comment Share on other sites More sharing options...
wacko2000 Posted September 21, 2010 Report Share Posted September 21, 2010 I have never heard or seen of oversized bowls for stock carbs, why not just run some bigger carbs?? Quote Link to comment Share on other sites More sharing options...
wheredahoesatracing Posted September 21, 2010 Author Report Share Posted September 21, 2010 I have never heard or seen of oversized bowls for stock carbs, why not just run some bigger carbs?? well that would require more money than i got!! bigger intakes bigger filters bigger carbs $$$$$$$ Quote Link to comment Share on other sites More sharing options...
Nutwood 472 Posted September 21, 2010 Report Share Posted September 21, 2010 well that would require more money than i got!! bigger intakes bigger filters bigger carbs $$$$$$$ check out CP industries,they make cubs,ect but I seen they advertise larger stock carb bowls,but dont list brand or size,but you can call Andy at M&M atv,site sponser and I'm sure he can tell what out there. Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted September 21, 2010 Report Share Posted September 21, 2010 Just get a machine shop to make you a spacer plate to put between the bowl and the car body. Kinda like a reed spacer, but goes between the bowl and carb body to move the bowl down further. Should be cheap for a machine shop to make you some... Quote Link to comment Share on other sites More sharing options...
brugal Posted September 21, 2010 Report Share Posted September 21, 2010 oversized stock carb bowls I never heard of em. Quote Link to comment Share on other sites More sharing options...
alcoholbanshee Posted September 21, 2010 Report Share Posted September 21, 2010 Just get a machine shop to make you a spacer plate to put between the bowl and the car body. Kinda like a reed spacer, but goes between the bowl and carb body to move the bowl down further. Should be cheap for a machine shop to make you some... moving the carb bowl down will not really help at all...........................You need it larger in all other areas than down. Look at it this way. What good does fuel in the bottom of the bowl do, if the main jet gets uncovered. One option is to remove 1 of the floats in each carb. That will give you more volumn of fuel in the bowl................................ Another option is to replace the needle and seat and run a fuel pump........................... Quote Link to comment Share on other sites More sharing options...
wheredahoesatracing Posted September 22, 2010 Author Report Share Posted September 22, 2010 thanks to everyone for your input i will call m&m on wed. and i have one float removed out of each carb just kinda worried that they might run out on a long pull so far i have been good in the 300 foot drags but im going to ls in oct and i just want to be safe. what kind of mods do i have to do to run a fuel pump besides the needle and seat? Quote Link to comment Share on other sites More sharing options...
