blaster
I have a brand new never run blaster crank,2-piston/ring sets,whole bottom end,cylinder/head,crank bearing
I have had this for two years tucked under my bench all parts were bought from FAST brand new
since then I had a cleaning fit and chopped the blasty into 100 peices,ill do trades let me know
Rad valve $75.00 never used with gaskets
WSM piston with coating $50.00
Wiseco piston 66.25 mm $50.00
New oem crank and bearings never used in the bottom end $350.00
Clutch $20.00
Cylinder and head $60.00 orginal porting .020 boar
Shipping will be determined once destination is finalized. I will make deals and consider trades! Mostly DRAG parts
