4mm stock cylinders, 4m crank, and +3 forward stock width STELLAR drag a-arms.
prices droped
i have a hot rods 4mm ,115 rod crank that is out of my own personal bike im going 10mm . it is in good condition and perfect runable shape.
no pics of the crank because the lower half is still in the bike i sold a guy who was running these stock cyl. my cub topend , so the crank i did not pull yet. $250 firm
also a set of 68mm big bore domes alil rough but could be polished up and ran, they are 22cc (pistol not for sale haha) $10
aslo for sale a set of like new STELLAR +3 forward stock width drag arms and spindles including tierods and all heims, powder coated mat. silver.
im going to a single front a-arm chassis so no need for these $400
all prices are obo and do not include shpping or paypal fees.
thanks chris
I seen you said the cylinders were ported in Kalamazoo. I live I Michigan and am interested in the crank. Where are you located? Would I be able to pick up in personto avoid shipping and fees?
hey, i am located in belleville michigan. right at the i-94-i-275 crossing, i see your in roseville, i work at diamond racing pistons in clinton township 15 mile and gratiot we could arange a meeting if you would like
thanks
yes sir for 200 i will include the pistons, cylinder, wrist pins and wrist pin bearings. the pistons show som detonation but where running fine.
ok, i'm really interested. can you take some measurements for me tho? what is the measurement from cylinder deck to the roof of the exh, main trans, sec trans, and boost port? i want to see if the timings are outta league for me etc. also, the bore is totally ok to run? also, if i buy them and they show up not as advertised or they won't work for me, would you refund? thanks.
Great seller, great guy! Those r my old cylinders, I just bought a set of cubs from him. He installed them for me, and then had me over and we rode for about an hour. Dont worry about him. Like I said great seller and great guy!
i work nights so its 3 somthing in rhe am now ill grab your numbers in the am for you, the bore is ok to run,there are some marks up and down that will not effect anything, the pistons show detination which is hard on the ring gaps. these where running like i said, the guys squish was all jacked and he was having issues with o rings in the head. if i was doing the motor id replace them for peice of mind.
i will stand by all my parts 100 %, however you are responsible for the setup like base gasket thikness, domes , squish, all the builder crap..lol
im selling a good useable set of cylinders, the pistons and extras are just through ins.. use them at your discretion.
anyone that has done deals with me will confirm im a strait shooter, i give the most accurate info i can and stand behind my stuff.
thank and call if yo would like 1734 679 6735 chris
I will give you a call around 10 or 11am. Thanks chris.
ok for the specs from the deck surace of the cyl.
the exhaust port is: 1.135 inches down bottom of port is 2.165 down
main transfers are: 1.670 to top and 2.165 to bottom
sec transfers are: 1.663 to top 2.185 to bottom
intake ports are: 2.970 to top and 3.905 to bottom
with the pistons included and no base gasket the pistons stuck aprox. .070 out of the cyl. the domes that where in this setup were wrong so i have no squish info ore base gasket/ spacer info. hope this helps thanks chris
