252wheelieking Posted September 17, 2010 Report Share Posted September 17, 2010 Just blew my banshee up & looking for new set-up. I wanted sum opinions on this set-up: 1st set-up: stock crank +4 timing CPI inframes Cheetah Cub/stock porting 68mm wiseco pro lite VF 2 reeds Boss Racing intake w/ built in crossover tube 34mm PJ Keihin carbs 2nd set-up: Same thing except im installing +4mil/110 rods How much HP should the stock crank set-up produce? How much HP should the +4mil/110rods produce? How well do the CPI inframe pipes worked with the stock Cheetah Cub? Do the CPI inframes bolt up to Cheetah Cub without bumping the cylinders? Thanks for all opinions? Quote Link to comment Share on other sites More sharing options...
Hilarious Posted September 17, 2010 Report Share Posted September 17, 2010 how are you going to using this bike? i would go the 4mill route (with 115 rods instead of the 110) and plan on adding a clutch and possibly a bit more swingarm to your list. Quote Link to comment Share on other sites More sharing options...
252wheelieking Posted September 17, 2010 Author Report Share Posted September 17, 2010 how are you going to using this bike? i would go the 4mill route (with 115 rods instead of the 110) and plan on adding a clutch and possibly a bit more swingarm to your list. How much HP should this set-up have with +4mil/115 rods? How much more on the swingarm? & do you mean just new clutches or the basket & clutches? Quote Link to comment Share on other sites More sharing options...
J-Madd Posted September 17, 2010 Report Share Posted September 17, 2010 90 - 95 hp well tuned on race gas. CPIs will hit the cylinders. Just use washers on the brackets to move them out a little. Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted September 17, 2010 Report Share Posted September 17, 2010 I hope that bad boy is gonna be stretched! It's gonna be a mosnter. Quote Link to comment Share on other sites More sharing options...
tedd1 Posted September 18, 2010 Report Share Posted September 18, 2010 I built a 421 a couple seasons a go that made 90+ hp on gas with Shearer in frames and +8 swinger. Clutch wouldn't hold and after burning up a couple, I installed a Slingshot. It cured the clutch problem but wouldn't shift. So, I installed an over ride trans. Point is, as much as I love my cub, about the only thing it is good for is drag racing. If you intend on doing anything else with this bike, I would suggest a good stock cylinder set up for the type of riding you want to do. If I were to build duner today, I would look seriously at a Serval cylinder. Same price as a Cub with 4 stroke torque... Rick Quote Link to comment Share on other sites More sharing options...
Balzout Posted September 20, 2010 Report Share Posted September 20, 2010 I built a 421 a couple seasons a go that made 90+ hp on gas with Shearer in frames and +8 swinger. Clutch wouldn't hold and after burning up a couple, I installed a Slingshot. It cured the clutch problem but wouldn't shift. So, I installed an over ride trans. Point is, as much as I love my cub, about the only thing it is good for is drag racing. If you intend on doing anything else with this bike, I would suggest a good stock cylinder set up for the type of riding you want to do. If I were to build duner today, I would look seriously at a Serval cylinder. Same price as a Cub with 4 stroke torque... Rick Interesting news on the serval cylinders, but I could find no info about them. Could you please post where to find them. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted September 20, 2010 Report Share Posted September 20, 2010 Interesting news on the serval cylinders, but I could find no info about them. Could you please post where to find them. Right at the bottom of the page. They are a pretty new cylinder so there isnt a whole lot of posts. http://bansheehq.com/forums/index.php?showtopic=134580&st=0 Quote Link to comment Share on other sites More sharing options...
