Cheetah Cub & CPI inframes
252wheelieking
Just blew my banshee up & looking for new set-up. I wanted sum opinions on this set-up:
1st set-up:
stock crank
+4 timing
CPI inframes
Cheetah Cub/stock porting
68mm wiseco pro lite
VF 2 reeds
Boss Racing intake w/ built in crossover tube
34mm PJ Keihin carbs
2nd set-up: Same thing except im installing +4mil/110 rods
How much HP should the stock crank set-up produce?
How much HP should the +4mil/110rods produce?
How well do the CPI inframe pipes worked with the stock Cheetah Cub?
Do the CPI inframes bolt up to Cheetah Cub without bumping the cylinders?
Thanks for all opinions?
how are you going to using this bike?
i would go the 4mill route (with 115 rods instead of the 110) and plan on adding a clutch and possibly a bit more swingarm to your list.
How much HP should this set-up have with +4mil/115 rods?
How much more on the swingarm? & do you mean just new clutches or the basket & clutches?
I built a 421 a couple seasons a go that made 90+ hp on gas with Shearer in frames and +8 swinger. Clutch wouldn't hold and after burning up a couple, I installed a Slingshot. It cured the clutch problem but wouldn't shift. So, I installed an over ride trans.
Point is, as much as I love my cub, about the only thing it is good for is drag racing. If you intend on doing anything else with this bike, I would suggest a good stock cylinder set up for the type of riding you want to do. If I were to build duner today, I would look seriously at a Serval cylinder. Same price as a Cub with 4 stroke torque...
Rick
Rick
Interesting news on the serval cylinders, but I could find no info about them. Could you please post where to find them.
