ludeing Posted September 15, 2010 Report Share Posted September 15, 2010 I was riding and my Banshee started bogging really bad and i noticed one of my carburetor joints was ripped on top and was sucking air! So i took it apart and am buying a new one but when i put it back together do i put any sealant on it before i install? Because when i took it apart i seen there was stringy black stuff peeling off it like it had been sealed before! please help Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted September 15, 2010 Report Share Posted September 15, 2010 Your talking about the metal cross over tube right? If so, then you can put a bead of silicone around the joints then clamp it tight if you like. Just make sure the rubber on your intakes are not cracked is all. Quote Link to comment Share on other sites More sharing options...
ludeing Posted September 15, 2010 Author Report Share Posted September 15, 2010 Its the piece that connects to the carb and the v force reeds and on top it connects to a tank but when i pulled it off of the vforce it peeled off!! what silicone do i use to put it back together! Your talking about the metal cross over tube right? If so, then you can put a bead of silicone around the joints then clamp it tight if you like. Just make sure the rubber on your intakes are not cracked is all. Quote Link to comment Share on other sites More sharing options...
prssantana Posted September 15, 2010 Report Share Posted September 15, 2010 I wouldn't use silicone there. If you do then be careful. Any excess will squish out and you could end up with chunks of silicone in you bottom end. Also sounds like you have a boost bottle. From what Ive read they cause the cracking in the tubes you're talking about and you are better off with the stock crossover tube. The crossover and clamps should be sufficient. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted September 15, 2010 Report Share Posted September 15, 2010 I always use silicone on the intakes. Unless you put a HUGE amount on there and it squeezes out, anything sucked in will just burn, it's not a bige deal. Put a thin, skim coat on both sides of any gasket you use. I also use blue loctite on the intake boot bolts, I've had mine back out as well...another sure fire air leak. Some people have luck without RTV or silicone...I've had leaks in the past on different builds. The key is to not get stupid with it...just use your head. Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted September 15, 2010 Report Share Posted September 15, 2010 I use three bond everywhere like stated above ,stock intake boots have a petrueded rubber ring that seals to the cage but i just dont trust it so seal it Quote Link to comment Share on other sites More sharing options...
prssantana Posted September 15, 2010 Report Share Posted September 15, 2010 Sorry silicone on the gasket is fine. I miss understood it. I thought you meant on the crossover tube. Quote Link to comment Share on other sites More sharing options...
