clutches? (non lockup)
chrisp250r
  • Replies 32
  • Created
  • Last Reply
Top Posters In This Topic
I would advise against a e-z pull clutch because the way it works doesnt disengage the clutch as much as a stock lever. Also keep the cable greased.
I disagree...
I've had the FAST EZ Pull lever and perch on my bike for years, my stocker, my 4 mil with no override or lockup and my current 10 mil with a lockup and override and I have zero clutch issues. I do get a new cable every year or every other year...for 12 bucks or so, they're a good investment.
You'd be amazed how easy the clutch pull can be with this lever, a new cable and a greased up pivot point on the perch even with HD springs.
It feels like a 125 cc dirt bike....
whats that "easy pull" lever look like? is it just the cr lever set up? the MSR esy pull does SUCK!!
i use the quick adjust cr lever/ perch assembly..
i also have used the tusk/ tommey clutch it works great.!
i just put a driveline performance? clutch kit in from ebay. into a 421 cub it pulls hard but its on the stock lever and the cluthc is holding up great looked good also.
That's the 2nd time i've heard of someone using a CR lever. MY buddy has one on his cub for years. Very easy to pull and works better than my ASV i believe.
CR is the bend of the lever.
Just like handlebars...CR Hi, CR Low, etc.
The lever from FAST has a ball bearing in it...which I'm sure helps the easy pull.
We have our F.A.S.T. clutch on sale this month and i havent found a better feeling/working lever yet than the one we sell with the bearing in it.
I just put one of these on mine with a new cable. My clutch has never been this easy to pull. Get the one with the bearing...
